Camaro wont start.(no fuel)
Old Jan 2, 2011 | 03:52 PM
CamaroZilla's Avatar
Car: want a 3rd gen camaro
Engine: prefer a v6
Transmission: with a auto
I have a 89 Camaro RS with the 305 TBI in it. It will Crank and Crank but will not start. Got it to start once with starting fluid but cant get it started again. When it fired it would just die. Seems like im not getting any fuel threw the injectors. I can't seem to hear the fuel pump running. It was running a few days ago when i moved it out of my garage. I was wondering if there was a fuel cut off switch for these or any easier test other then dropping the fuel tank? I changed the fuel pump relay so far. Thanks for any advice in advance!
Old Jan 2, 2011 | 04:35 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Camaro wont start.(no fuel)
ok well first thing you want to check is fuel pressure. if no pressure than you have a fuel pump problem. if you have fuel pressure, you want to check the injectors to see if they are getting signal. a very common problem for our cars is the ignition control module to go out. which sometimes can cut out the injectors and not the spark, or vice versa. or both.
Old Jan 2, 2011 | 04:40 PM
Engine: prefer a v6
Okay thanks alot. One question how would i be able to test the fuel pressure on the Camaro?
Old Jan 2, 2011 | 04:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
a local auto parts store can sell you one. on TBI's, they have you cut your fuel line and T into it so you can have the schrader valve to hook the gauge up to.
Old Jan 2, 2011 | 04:59 PM
Engine: prefer a v6
okay thanks. Any other suggestions?
Old Jan 2, 2011 | 05:19 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
nope...check those things and see what you come up with.
Old Jan 2, 2011 | 05:49 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
My vote is for the fuel pump. Unscrew the feed line and put it in something that can hold gas, and have someone turn the key on, and see if gas comes out. If no gas comes out, your pump is probably fried.
Old Jan 2, 2011 | 09:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
dont let obvious things such as an empty gas tank mess this all up either
Old Jan 2, 2011 | 11:03 PM
Engine: prefer a v6
so i took the feed line off and turned the key.. i got nothing... so i lift up the carpet in the rear and its all nicely cut out and sealed. so i unscrewed the screws to look and see if the previous owner cut the tank. the tank has no scratches on it so this week im gonna replace the fuel pump.
Old Jan 2, 2011 | 11:09 PM
Well, since he allready hacked the floor open, you might as well make good use of it. Good luck!
Old Jan 3, 2011 | 01:02 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
wow it was already cut open eh? dont see that everyday
Old Jan 3, 2011 | 07:32 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Before u buy a fuel pump check the relay you never know I always check cheaper parts too.
Old Jan 3, 2011 | 06:52 PM
Engine: prefer a v6
my first thought was the relay so i bought a new one and still nothing.. yeah its nicely cut open i will post some pics.
Old Jan 6, 2011 | 10:04 PM
Engine: prefer a v6
well since about an hour ago i took the old pump out and replaced it now im getting fuel out of the feed line but nothing is coming out of the injectors. the battery seems to be dead tried to jump start it and got nothing so now its in the garage sitting on a battery charger on 2amps till the morning when i go out to try it again.
Old Jan 8, 2011 | 06:29 PM
Engine: prefer a v6
ok we tried a new battery and used an injector noid and it seems there is no power going to the injectors any ideas on a reason for that?
Old Jan 8, 2011 | 09:29 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Could be a number of things you ECM will control power to the injectors and I know things like now oil pressure will cut off fuel as well are you getting any check engine light or at least see if you have a code even if your light is nOt on dues to maybe burnt out.
Old Jan 10, 2011 | 09:52 PM
Engine: prefer a v6
after more research we found that the PO had put in a VATS bypass and it looks pretty getto. tomorow im going to properly solder in the resistor and try it again.*keeps fingers crossed*
Old Jan 10, 2011 | 10:03 PM
Good luck on finding the problem, seems like you needed a new pump, anyway so now you don't have to worry about it going out for a while. I hate VATS, its just one more reason I love the early third gens.
Old Jan 12, 2011 | 08:20 PM
Engine: prefer a v6
well the VATS has the resistor so that doesnt seem to be the problem. so far we have replaced: fuel pump, pump relay, and ICM. the is power going to the injectors but still no puls its there any other problems that could be stopping the injectors from firing?
Old Jan 20, 2011 | 01:53 AM
Zeeboinc's Avatar
Car: '89 Iroc Z
Engine: Paxton SN-92 305
Transmission: 5 spd
I'm getting a similar problem on my wife's 88' v6 Camaro. Was running fine, started stuttering mildly whenever at a stoplight approximately 2 weeks ago, then yesterday started her up and drove for 12 seconds and the car cut off. Tried to restart and it would stay on with 1/2 open throttle in Park but would die if put in gear. Now I can hear the engine cranking and what appears to be spark however it doesn't seem to want to kick over and start as if it's not getting any/enough fuel. Probably gonna move down the line (pump relay, pump, kill the wife, cash insurance for new car, etc.)
Old Dec 10, 2011 | 04:05 PM
Stryker1028's Avatar
ok im having a similar prob at first i lost all oil pressure and the car shut off i replaced the oil pressure switch it cranked up with normal oil pressure for about 30 min the ni cut car off changed oil and oil filter now it will turn over but wont crank at a lose as to what to do
Old Mar 25, 2012 | 10:20 PM
Ghostfac3's Avatar
Car: 91 rs camaro/89rs camaro
Engine: 5.0 ho/5.0tbi stock
Transmission: 700r4/700r4
I have this exact same problem i changed my injectors a month ago and was on my way to get tires put on and i just started coasting. So i have changed the filter and the fuel pump and strainer the batery was dead so i boosted it. And had the fuel line dissconected to see if the fuel came out it took awhile but it was not coming out of the two injectors and it was befor.
Old Mar 28, 2012 | 01:18 PM
Engine: prefer a v6
idk if its a help for you but the problem with my car turned out to be a bad wiring harnes and bad grounds in a few spots.
Old Mar 28, 2012 | 02:01 PM
Ghostfac3's Avatar
I have been checking the wiring the injectors work now but as of now i have no spark i changed the ignition coil and to night when i get out of work im going to get a new distributer.i have been looing for where all the grounds might ne but tjere is a lot of stuff on this board to sift throu.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
