Dual Snorkel 70-72 Camaro on TBI?
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
I was going to install a dual snorkel from a L69 on my 89 TBI Bird. Then I saw on ebay a dual snorkel new for 70-72 Camaro and it does not have the Thermac on either side. Anyone ever try this from that model? It looks like it should fit. Comments.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Dual Snorkel 70-72 Camaro on TBI?
Thermac is a simple and smart device. The inlets are a little small but maybe you can open them up some.
Though it's better to start the race with the engine up to operating themperature, in wich case the thermac is not active anyway.
Car: 89 Formula
Mainly curious if it fits with little modifications. I saw reproduction 70-72 dual complete on ebay for $200 and they sure look close but I have access to the stock L69 set up.
Engine: gone
Transmission: gone
Axle/Gears: gone
cant say for sure if it will clear the a/c compressor. plus if you still have the smog pump and diverter valve installed, as well as the heater valve.....the inlet tubes being longer on those older cars could hit
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I was thinking about the same mod for my 1989 TBI.
Another alternative would be to weld another snorkel on the other side of the existing airbox.
I currently have my car stored for the winter season, but as soon as I get it out I will get me some polystyrene foam and shape up a dual snorkel setup out of that to measure whether it fits or hits.
A third alternative would be to fall back on a 3rd party solution as the ones offered by a company named "spectre", but that would kind of spoil the stock look of the vehicle, whereas with a dual snorkel setup it would still look "as shipped" to the uninitiated.
Car: 91 Trans am
I ended up with one big snorkle on the driver's side, lots of space there
https://www.thirdgen.org/forums/tbi/...l-diy-tbi.html
Car: 89 Formula
Hey thanks guys for the input. The DIY one very impressive. Nicely done. Now I have some great information and experience from others.
Engine: gone
Transmission: gone
Axle/Gears: gone
im going to be sealing my cowl hood off from the engine bay and only takign air in from the hole in the hood.
Car: 91 Camaro
Engine: 305 TBI
Transmission: 700R4 Automatic
I tried the dual snorkel on my 91 and the back of it would not go down all the way because of the distributor. might could be fixed, don't know.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The thermac device is only held in with a small diameter pin. You can cut it out and free any obstruction in the intake path.
92camaroJoe
Aug 13, 2015 06:07 AM
