heads/cam/intake info and ideas
Old Jan 24, 2011 | 12:03 PM
NightHawk1824's Avatar
Car: 1991 Pontiac firebird #126 bandit
Engine: 305 tbi
Axle/Gears: stock 2.74's
1991 pontiac firebird 305 t.b.i 700r4
Hey guys i am new to the 305 tbi motor but not new to working on cars, I have finally started to get a list together for a decent build for my 305, I know everyone says go with a 350 but i am staying with the 305 to have something different... Anyways i have decided to go with 3.42's out back and for up front i am going to use the vortec heads either the 906 or 062's whichever i find first and a lt1 cam (may go a little bigger not much) I am now onto the intake manifold...I know there is the gmpp intake as an option but i was wondering if i can use something like this: Edelbrock 2116 - Edelbrock Performer Vortec Intake Manifolds and just use a t.b.i adapter?
any other options let me know i am open to suggestions
Old Jan 24, 2011 | 12:18 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: heads/cam/intake info and ideas
I'd do the edelbrock 7116 with tbi adapter
Old Jan 26, 2011 | 09:32 AM
Engine: 305 tbi
1. Casting #10239906
casting #12558062
Either #062 or 906’s does not matter same flow rating.
'96-'99 trucks. They require a specific intake manifold,
2. Edlebrock Performer RPM Intake Manifolds #7116 (tbi plate)
3. Hedman headers
4. Hedman y pipe
5. Comp cams 1.6rr
6. Gm performance valve springs (part#12499224)
7. Fuel pressure regulator and 60lb injectors
8. not sure on lifters yet
thats my current list,
I plan on going to a 750cfm carb in the future but wanna get all the basics done first.
for my cam i am going with the lt4 hot cam 218/228 .525/.525
any other suggestions?
Old Jan 26, 2011 | 09:44 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
casting #12558062
3. Hedman headers
4. Hedman y pipe
5. Comp cams 1.6rr
3-If your going hedman, may as well get the long tubes.
5-don't forget the proper length pushrods to match. since your replacing them, may as well get the .080 wall.
7-Be sure to replace tbi pump. its max pressure is around 14psi. I have a tpi in mine, with a steady 20psi with modded regulator.
8-AcDelco lifters
Old Jan 26, 2011 | 11:34 AM
Engine: 305 tbi
I have a walbro 255 already, My pump went out on me last summer and i already knew i was going to upgrade everything come spring so i planned ahead.
don't the long tube have clearance issues? Something about having to notch the sub frame to get them to clear or something with a/c
Old Jan 26, 2011 | 01:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
750 carb will be way too much - won't need over 600cfm carb when that happens.
I'm assuming you'll be carbing as soon as these mods take place? Not really a need for the TBI adapter - if not swapping to carb at same time, you'll be sitting in a non-running car unless you know how to program TBI chips - after these bolt-ons car won't run at all off a stock chip.
Old Jan 26, 2011 | 02:46 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I had a friend mock a bracket for the a/c, cost'd him 10$ gave him a $20. they came close to the k-member, nothing a hammer couldn't take care of.
+1
Old Jan 26, 2011 | 04:43 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I think you need to decide if you want TBI or carb. you dont need a 255lph to feed a carburetor that runs on 7-10 psi..
Old Jan 26, 2011 | 10:31 PM
Engine: 305 tbi
carb it is, and i have had the walbro installed for awhile now..i got it for 50 bucks so no point in not using it at the time my fuel pump went out,
anything i am overlooking?
Old Jan 27, 2011 | 05:46 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
carb it is...anything i am overlooking?
The peanut cam?
For carb related information, you wil find a lot more in the carb forum.
Old Jan 27, 2011 | 08:09 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Originally Posted by thomas1976
The peanut cam?
Yeah deffinately gotta change the cam. cam and heads are what is holding tbi motors back to begin with
Old Jan 27, 2011 | 09:14 AM
Engine: 305 tbi
my third post i say i am going to use the lt4 hot cam, 218/228 .525/.525
Old Jan 27, 2011 | 09:21 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yes you did. Sorry sir.
Old Jan 27, 2011 | 09:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to need to take those heads to the machine shop to work with that cam. At the minimum you will need to have the valve guides cut, install new springs, and the pressed in studs removed for screw in studs. This will add an easy $300 to your budget if not more.
Old Jan 27, 2011 | 11:51 PM
Engine: 305 tbi
I am not to worried on the cost (not saying its not an issue) I am just looking for an all around performing car. i am not wanting a 11 sec car or anything like that just a fun street car that i can take on our cruises but still be able to at least hang with stock lt1's
toones
Jan 6, 2016 06:00 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Fox118
Sep 1, 2015 04:07 PM
dbrochard
Aug 30, 2015 05:56 PM
ambainb
Aug 29, 2015 12:43 AM
