what should i set my timing to?
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
l03/700r4 with stock manifolds and y pipe into a side dump cherry bomb, open element filter. what should i set my timing to?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: what should i set my timing to?
I run mine at 6*and it pulls real nice.I started at 4*to see if there was spark knock .It did not. 6* turned out to be the sweat spot with mid grade fuel.
Engine: gone
Transmission: gone
Axle/Gears: gone
with a stock chip I ran mine about 6-8 degrees. I dont know if your supposed to change your timing for an aftermarket chip?
Engine: TBI,5.0
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
since I can read my chip....set base timing to chip... really need to match..
I timed mine by ear which ended up at 14 degrees.......set chip to 14 degrees
also.
also.
Engine: gone
Transmission: gone
Axle/Gears: gone
It will give you a little more oomph down low. You'll like it trust me. do it!
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
ive never messed with timing, i hope i can find someone to do it
. i couldnt even see the degree thing on the harmonic balancer. then again it waas night
. i couldnt even see the degree thing on the harmonic balancer. then again it waas night Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If your tuning is stock and your car is basically stock with the stock heads, set it at 0°. Swirl port heads are fast burn heads and do not nessecitate a lot of intial advance like non SP heads do.
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: stock
I found a site that said base timeing is supposed to be 6* it also says idle is supposed ot be 400 rpms and i can't get mine to idle down that low. So which is it? 0 or 6. Also doesn't the idle and base timing correlate? if the idle is fast it throws off the timing???
http://www.iroczone.com/2009/10/1989...pecifications/
