*help* the more i research bout my cam the more problems come up
Old Mar 21, 2011 | 09:46 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
so my blue racer cam wolverine is a tappet and im really close to putting it in everyone knows prep takes longer than the build
my friends going to help me his main concern was getting enough feul to power to make it run right told me to ask summit so i did
asked
summit
jegs
crane cams
crane cams say it would work
thus brings us to jegs.. ..
jegs threw something in my face i didnt even think about
he says
"it will not work due to the fact the lifter bore size is bigger cause it is roller there fore the tappet lifter will be to small. . . "
im fustrarted beyond belief im aksking opinions/facts
regarding this
lets say they are smaller will it still run decent
wat can i buy (besides a new cam and lifters) in order fot it to fit
if any one else has done a build like this plz help
roller to tappet cam . .. .
Old Mar 21, 2011 | 10:08 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: *help* the more i research bout my cam the more problems come up
lifters are the same size. and btw when you purchased that cam and posted it up most of us said it wasnt an ideal cam for your engine. you should get different pushrods for your setup. I am running a flat tappet cam in my engine where a roller lifter was once there with no ill effects. So you'll be fine as long as the parts are made properly.
Old Mar 22, 2011 | 07:21 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Originally Posted by dabird07
im fustrarted beyond belief ...
My advise, since you do not appear to have a clue about what you're going to do and your friend has certain preferences towards parts he prefers to work with is to listen to him.
If he fitted a cam before and tells you he's not certain this will fit, don't fit it.
Of course you can throw money at the cam you have now and pray, but the more sound approach would be to discard the current cam, sell it on ebay or somesuch and consider the loss "learning money", then ask your friend which cam he would pick up for your car and have him help you fit it.
As undercoverTBI already posted you pretty much ignored the advise provided in a previous post, so I guess this post is wasted energy on my behalf, but you have someone who wants to help you and come here asking for information to contradict what he's advising you.
If you haven't upgraded your fuel supply your friend might be right about the fuel part. Read the stickies to learn more about that. It's all there.
Old Mar 22, 2011 | 08:20 PM
dabird07's Avatar
Car: 92 firebird
im not ignoring at all i read all of the post im just wanted to use wat i got
im also not contardicting anyone
i got valve springs
pushrods and timing chain
id listen to everyone saying that it wasnt a ideal cam i didnt ignore it
i already have the cam might as well try it
also everything so far is ideal
pudhrods springs
imma go to autozone ask for stock lifters
compare diameter
worse comes to worse like solatiare said it will be learning money
i hate to know yall think this. . .
Old Mar 22, 2011 | 08:28 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Well go to autozone. you will only need to buy one lifter first to compare.
Old Mar 22, 2011 | 08:43 PM
dabird07's Avatar
Car: 92 firebird
so went to autozones website look at stock lifters
.8421 in diameter measured my tappet ones and they measured a lil over .8 so good news!!
and also i was told hydrauliic lifters are same size in diameter just like
tbi said never hurts to check
so happy now. . .
leaving stock bearings in cause im leaving motor in car just taking off front bumber
Old Mar 22, 2011 | 08:52 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Well when you remove the cam visually inspect the cam bearings, key part is you do not want to knick them too badly when removing and installing the cam. you should be fine.
Old Mar 22, 2011 | 09:29 PM
dabird07's Avatar
Car: 92 firebird
yeah i hear they are a pain imma buy that cam puller should make things alot easier gotta wait till i have the weekend off and samething with my friend cant wait going to be my first build/teardown thread!
Old Mar 22, 2011 | 10:05 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah its not as bad as you think. Just make sure on the intake use a thick bead of black rtv silicone. dont mess with the end seals. I also like to put silicone around the water ports on the intake gasket.
Old Mar 22, 2011 | 10:23 PM
dabird07's Avatar
Car: 92 firebird
thanks! i know ill need new valve cover gaskets and u answered my next question should be within the next few weeks!
Old Mar 22, 2011 | 10:34 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well i reread it just now. You still have to use the normal gaskets on the sides for the ports but on the end's you use the silicone.
Old Mar 23, 2011 | 04:57 PM
dabird07's Avatar
Car: 92 firebird
good news!
went to autozone
same size as u said !! (no offense)
for others reading this thread
theres no difference in diameter between roller hyd and tappet hyd
ussaully thats the case (correct me if im wrong)
so everything set!!
Old Mar 23, 2011 | 05:24 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Hey ya gotta learn somehow.
I wonder wtf the jegs moron was thinking lol.
Likely trained at the comp cams institute of ignorance.
Old Mar 23, 2011 | 07:59 PM
dabird07's Avatar
Car: 92 firebird
hahhaah welll i got everything set the main concerned is wat everyones been telling me is its going to be a pain to run right!
next thing on the list of learning diy prom
but back to topic
waiting for friends schedule then hopefully this weekend will be the star of
*project breathe*
dont hate. .. .
Old Mar 24, 2011 | 08:24 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
we wont hate dont worry
Old Mar 25, 2011 | 07:48 PM
dabird07's Avatar
Car: 92 firebird
hahahah
well need a tunin equipment and weathers messing up this build . .
Old Mar 26, 2011 | 11:21 AM
dabird07's Avatar
Car: 92 firebird
so been told by summit on the phone that it will work with custom chip
on emails says tbi want work with that due to lobe being 110
but a custom chip might help
so downloaded tune pro and amm gettin a ecm flash ordeal that
xch3no2 suggested in a other post to tune
(due to the fact i will be making more mods figure this be cheaper than keep buying chips)
so with lifters fit
50/50 chance its goona run right
going to be interesting
believe me and my buddy can make it work
Old Mar 26, 2011 | 11:48 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
so when are you ordering the dynamicefi.com setup?
Old Mar 26, 2011 | 12:22 PM
dabird07's Avatar
Car: 92 firebird
well it sucks to say but next pay check bills came into play and took half my check
(i only make minimum)
so i dont have enough to get it yet so two weeks from now. . . .
it sucks.. . .
bi weekly takes a whiile
so pushes this build even farther . .. .. .
unless theres a cheaper alternative route to take
but any who
everythings ready except for that .. . .. . .
im impatient. ..
1992 Trans Am
May 10, 2023 07:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
wayshegoes
Aug 17, 2015 12:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
