cam swap?
Old 03-24-2011, 12:22 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
cam swap?
do i have to pull the motor to swap cams?
Old 03-24-2011, 12:31 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: cam swap?
There is only one cam, and no, you dont have to pull the motor. Although there is a bunch of stuff that has to come out and you may have to unbolt the through bolts in the motor and slightly jack the front of the motor up to angle it a little for that last inch or so.
Old 03-24-2011, 01:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cam swap?
Remove radiator. Need an extra set of hands to pull back the crossbars in front of the radiator a tad - the cam wants to install exactly where those crossbars make an "X", but it can be done in the car.
anesthes
03-10-2016 10:35 PM
beastin91rs
10-09-2015 07:38 AM
Cameeeero
09-18-2015 04:00 PM
theshackle
08-22-2015 06:52 PM
theurge
08-21-2015 12:46 PM
Quick Reply: cam swap?
