L03 fuel pressure
Old Mar 26, 2011 | 11:28 AM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
L03 fuel pressure
I want to install a fuel pressure gauge and need some options. I have a gauge that says its fr carbed motors but i think i can make it work on the l03 since the prssues dont get higher than 15 psi. Anyone's input would be appreciated.
main reason for this is that somtimes the car boggs down with wot. replaced CTS, IAC, fuel filter, EGR, Ignition control module, installed factory temp t-stat, and plugs /wires.
doesnt make sense why sometimes it delays response or ignors WOT when above ~10-15mph.
Trans seems good. fluid was changed last weekend and install pan with drain. fuild was about the same as what i put back in. its shifts are firm. magnet had about 1/16th inch of particulate on it- I have seeen WAY worse
Gas I use Shell and BP mainly, if cant find a good one I go with whoever doesnt have ethonal
Old Mar 26, 2011 | 11:56 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: L03 fuel pressure
If you want to be able to see it while you are driving. You either have to have one setup in the car. or you can buy an inline fitting that goes onto your fuel line. where it connects from the frame to the engine in the engine bay. and run it up and set it on your cowl while you drive. I would not leave this permanently but to diagnose your problem should be okay. Thomas posted one up here a month ago or so in a thread. do a search for it.
Old Mar 26, 2011 | 12:20 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
I read through some similar posts and i ordered of ebay an adapter so i can see the pressure when i am loading up since that when i have intermittent problems. IDK if it the pump, regulator, TPS, or MAP.
I do have a small exhaust leak on divers side flange idk if that could be it either.
planning on hearders so not wanting to mess with it yet til i order 3inch y pipe.- another story
Old Apr 3, 2011 | 06:14 AM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
fuel pressure is a steady between 12-13psi at idle, off idle and WOT
Old Apr 3, 2011 | 01:14 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Fuel pressure tests will not reveal clogged injector screens.
Something to check.
Old Apr 3, 2011 | 02:57 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
ok how do I that? just remove the injector or is it part of the injector?
Old Apr 3, 2011 | 04:03 PM
xch3no2's Avatar
Transmission: TH400
It would be best to first observe the injectors operation, (aided w/a timing light). Look for a fine mist spray, no streamers or dripping.
If visual inspection reveals poor spray cones the injectors can be accessed by removing the screws holding the top of the injector pod.
Poor spray cones may be caused by clogged screens or if the injectors themselves become obstructed.
Old Apr 3, 2011 | 04:21 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
well the spray pattern looks fine to me spary conical and you cant see fine mist pulsating. checked map and it tested okay as well cant find anything on TPS and still looking for knock sys info.
Old Apr 3, 2011 | 04:55 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Clogged injectors sounds like my problem..sooo...I got a holley tbi and a bored out edelbrock manifold to remedy the situation.
Old Apr 3, 2011 | 11:19 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
well i changed the screens and that helps but still trying to figure out my knock counts
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
