timing problem
Old Apr 3, 2011 | 08:44 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
timing problem
ok so i was driveing my car for about a summer and decided to check my timing and it was at about 8* and i put it back to 0* but the car boged really bad so i put it at about 4* and the car ran good for a day but now it bogs worse than it di at 0 can anyone help me what might be the problem?
Old Apr 4, 2011 | 07:34 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: timing problem
mine is at 4* or 6* and she runs great.mine had a real bad bog and surge at idle it had 4.3 injectors in it so i put 350 injectors back in because i couldn't find any 5.7s at the u pull it yard..could be something else maybe misfiring or bad fuel spray,vacuum leak.etc
Old Apr 4, 2011 | 12:22 PM
kill4thril's Avatar
Engine: 355ci
Re: timing problem
i kinda got rid of the bog a bit but the car is really roughf when i try to get on it cuold that be a bad u joint?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
