injector problem
Old Apr 30, 2011 | 08:59 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
injector problem
i did the adjustable fuel pressure mod and put new gaskets on. put everything together and worked perfectly. later in the day the whole car started vibrating and i checked under the hood and looked at the injectors and saw one spraying in a cone and the other was just trickling fuel. i checked the fuel pressure an it was steady at 11.5 which was the same before the mod. my thought is a piece of old gasket got stuck on that injectors. would the small filter on the injector save it or could it have gotten damaged?
Old Apr 30, 2011 | 09:57 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: injector problem
TBI injectors are tough and usually hold up very well. Check injector connector - make sure that there is no bad connection before tearing fuel injector pod apart.
//RF
Old May 1, 2011 | 01:26 AM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
i will check that out thanks
ps do u know wat kind of flat head can reach the screw of the fuel pressure regulator from underneath (i did the dremel cut on the screw) its a really tight fit
Old May 1, 2011 | 03:02 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
sounds like maybe a particle is plugging up the screen on the injector.
Old May 1, 2011 | 04:53 PM
adilson delima's Avatar
Transmission: AUTO
i have a question, i replace the fuel pump and sending unit on my 90 RS right after the job was done, black smoke started to come out of the pipes and is shocking a little, any ideas?
Old May 1, 2011 | 05:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Really should start your own thread about this. Sounds like your getting too much fuel. That would cause the black smoke and engine shaking.
Old May 1, 2011 | 09:56 PM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
so i took apart the injector pod removed the injector and noticed a rip in the rubber gasket replaced it and i rotated the filter screen and it works perfect now. and to adilson delima ur fuel pressure regulator may not be set correctly causing u to get more fuel
Old May 1, 2011 | 11:50 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
sounds like you figured it out! great job man!
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
