Charcoal Canister Removal
Old May 1, 2011 | 08:01 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Can i remove the charcoal canister in my '89 350 TBI. If so what do i do with the hard line coming up the driverside frame rail? And i assume just plug off the port on the TB.
Thanks!
Old May 2, 2011 | 10:59 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Charcoal Canister Removal
1) Need to check with local inspectors - might not pass inspection without that emission piece.
2) When we swap to carb, we generally remove it (I did), I just attached a rubber fuel line hose to the third fuel hardline and ran it under the car so that no fumes or gas leaking would squirt out in the engine bay where there's hot manifolds, spark potential, etc. And yes, cap the vacuum port on the TBI unit so you don't have a vacuum leak.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
TBRays98
Sep 6, 2015 05:05 PM
