Timing on stock 305
Old May 31, 2011 | 06:22 PM
Ricke115's Avatar
Timing on stock 305
I have a 92 305 tbi completely stock with the exception on eldebrock headers, I went to set the timing the sticker under the hood says it should be timed at 0 degrees BTC (idk what BTC is) it idles a bit low but timing wouldnt effect that too much, it runs okay but seems to be a little sluggish, the timing teeth in the picture below, doesnt have any marking on it to tell me which tooth is what degree so idk where to time it, and ive also been seeing that they run really well at 6 degree BTDC so id like some opinions on where i should time it, and if anyone knows the timing on the teeth it would be appreciated thanks
Old May 31, 2011 | 09:09 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Timing on stock 305
The biggest toothe is 0. I like to run a stock L03 at 6 btdc. I normally run an advanceable timing light. But I think its the 3rd toothe?
Old Jun 1, 2011 | 05:41 AM
Ricke115's Avatar
so the biggest tooth is the one all the way to the right? and then 6 degrees is 2 teeth to the left?
Old Jun 1, 2011 | 11:17 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I hope someone chimes in. I dont have stock damper or cover on mine anymore I'm more going on memory
Old Jun 1, 2011 | 12:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Where it is now is 4* BTDC. See picture in this thread:
https://www.thirdgen.org/forums/tpi/...c-diagram.html
RBob.
Old Jun 1, 2011 | 02:41 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Way to go!
Old Jun 1, 2011 | 03:31 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have posted this before but feel I should post it again just in case someone dose not know that you have to have the EST wire unhooked to get your base timing mark.Thats what we are working with when setting timing.
I found this on a old thread concerning timing. Here's how they said to set it and a photo of the EST connection.=
Disconnect the EST wire, start car, adjust timing, shut off car , reconnect EST wire.
Old Jun 1, 2011 | 03:37 PM
Engine: TBI,5.0
You may already know this but if your car has "spark knock" under load or at any time at 6* you must turn the timing down to lets say 4* using the same procedure out lined in post above. Best to just carry your timing light and tools around with you for awhile.
Old Jun 4, 2011 | 02:26 PM
First_Formula's Avatar
Car: 1988 Formula Firebird (deceased)
Engine: l03 V8
Transmission: T-5 manual
So lets say i turned my distributor on accident without disconnecting my EST wire, How bad necessarily is that lol, When i fix my timing (its off right now) should i fix it with my EST still hooked up then try to fix it again with it unplugged?
Old Jun 4, 2011 | 07:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Warm up engine, shut it off, unhook connector, restart, time it , tighten down distributor, recheck after tightened, shut off, hook up again, done
Old Jun 4, 2011 | 07:23 PM
one92rs's Avatar
Car: SOLD!!!!!
https://www.thirdgen.org/forums/tech...photo-2-a.html
Old Jun 5, 2011 | 01:08 PM
Engine: l03 V8
Thanks, I'll get a timing light and do it up sometime soon.
Old Jun 9, 2011 | 06:27 AM
galletti's Avatar
Car: 1988 IROC Convertible
Since we're on this topic, I have an '88 IROC TPI LB9. I've added a 255gph fuel pump a while back, high flow cat and Flowmaster catback all 3". I feel it's running pig rich; should I advance the timing to 8*-10* instead of the 6*? Any other suggestions?
Old Jun 9, 2011 | 12:52 PM
Engine: TBI,5.0
From what I understand advancing base timing simply applies to when the spark is ignited during the compression stroke. I don't think it has much to do with running rich. I may be mistaken.
Old Jun 9, 2011 | 02:01 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well you have a tpi engine we are tbi guys over here. but I dont think advancing the timing a few degrees wouldnt hurt either way. but it probably will not fix your problem. you have may have too much fuel pressure. do you have teh adjustable regulator on it? that may be an option. The best bet is to post your problem on the TPI section of this site and see what they have to say.
Old Jun 9, 2011 | 07:34 PM
one92rs's Avatar
Car: SOLD!!!!!
so did this ever get fixed.
Old Jun 11, 2011 | 11:49 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I just did this. Ended up with around 6 degrees advanced for the sweet spot. When advanced too much it would have idling problems at startup or sitting at a lights so I just backed it off a hair until it ran right.
Old Jun 12, 2011 | 01:26 PM
Engine: l03 V8
I tried setting my timing to 6* advance and then 4* advance and it just ran horribly so I set it back to base 0* Runs great now
Old Jan 19, 2023 | 05:08 AM
Dazaz11/84T/A's Avatar
Car: 11/84 SA Trans sm
Transmission: TH700R4
305 chev timing teeth numbers
Attachment 391482
I just done mine as it was way out at 12° as the dizzy was loose and moved.
So from right to left inbetween first and second notch. 0,2,6,8,12 mines at 6°
Old Jan 19, 2023 | 05:09 AM
interesting ....carby ?
Old Jan 19, 2023 | 11:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Stock TBI heads are fast burn by design and do not need any advance built in to the base timing. TPI is different.
Old Jan 19, 2023 | 04:12 PM
Schurkey's Avatar
...reconnect/hook up EST connector, CLEAR THE CODE you created by running the engine with the EST disconnected. Done.
Azrael91966669
25
Jun 20, 2017 04:04 AM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
Leggman1
Aug 6, 2015 04:15 AM
