Couple of questions
Old Jun 21, 2011 | 05:48 PM
dpmalibu's Avatar
Couple of questions
I have an 88 Firebird Formula with a mild cam (don't know specs), Hypertech chip, 350 TBI off a caprice cop car, TBI spacer,headers and Flowmaster cat back. problem it it was idling very fast and there was no fast idle adjustment on the Throttle body . It was also running very rich so I retarded the timing and it started running very rough and no matter how I adjusted the timing nothing worked. So I checked the plugs and they were black.
i am figuringthe 350 TBI is too big. So I am going to put a stock 305 Throttle body back on it and new plugs and see how it runs.
my question is could the Chip be making it run too rich and most importantly will any TBI unit from any 305 work?
the engine code for my car is "E" if that has any significance.
Old Jun 21, 2011 | 10:26 PM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: Couple of questions
Could just be sensors or a bad tune on chip o2 iac tpi all would cause that
Old Jun 21, 2011 | 10:28 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
throttle position sensor, coolant temp sensor, bad oxygen sensor. vacuum leak. bad injectors. and more...
Old Jun 22, 2011 | 03:54 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
350 and 305 TB are the same size, the flowrate of the injectors and the tune are different.
Old Jun 23, 2011 | 02:27 PM
Ronny's Avatar
I would rule out vac leaks first. check all hose for cracks etc. also was the correct TBI base gasket used?
IAC should be closing thern opening when key on engine off. On a warm coolant it should be nearly closed like 95% so with engine running. Do a visual on thatlooking into TB bore at IAC inlet.
Old Jun 23, 2011 | 06:59 PM
dpmalibu's Avatar
Ok I will check these things out. Thanks.
Old Jun 23, 2011 | 07:33 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
The injectors being too large for the tune is more than likely your "rich" problem.
Old Jun 24, 2011 | 02:53 PM
Ronny's Avatar
Good point RF. I assumed the hypertech chip was for a 350 TBI cop car. Maybe a 305 chip.
Old Jun 24, 2011 | 03:39 PM
dpmalibu's Avatar
I have a set of 305 Injectors. I am going to try that and change the plugs and see what happens. Thanks
Old Jun 26, 2011 | 08:25 AM
dpmalibu's Avatar
problem fixed. Changed spark plugs, put 305 injectors in and re set timing. thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
