Holley TB
Old Jul 15, 2011 | 02:46 PM
tj25n1's Avatar
Car: 1991 rs
Transmission: auto
Holley TB
i have a 91 rs with a 305 tb. i am putting a 350 in it . i seen that holly sells an aftermaket tb that is rated for 675cfm. the 305 is 30 over witha big cam double hump eagle heads does any body think that would work
Old Jul 15, 2011 | 03:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: LETS TALK CARBS
Check Ebay, there are several aftermarket Throttle Bodies that are better than factory. The problem with TBI is that it's limited in tuneability after a while once you start getting into the more radical cam profiles.
Old Jul 15, 2011 | 03:31 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Holley TB
You probably don't need it unless your a high rpm turning 350
Old Jul 15, 2011 | 03:40 PM
tj25n1's Avatar
Car: 1991 rs
Transmission: auto
Re: LETS TALK CARBS
I am putting this car togther for my wife it won't be getting any more radical than the 350. which is 30 over double hump eagle heads and a good size cam. just wanted to make sure the cfm wood be enough for it. i want her to have power but be reliable enough to drive without any problems.
also the power windows dont work i check the fuse under the dash is there any or fuse or ? to check
Old Jul 15, 2011 | 04:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Holley TB
Don't spend the $ on throttle body. Spend on headers. Exhaust. Check power to motor if no power then electrical problem if power then bad motor
Old Jul 15, 2011 | 04:52 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Holley TB
Cough cough, http://dynamicefi.com/ may I also mention EBL has been around for a long time.
Old Jul 15, 2011 | 10:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Holley TB
Thomas you'll be happy to know im finally getting an EBL flash. We are doing a group purchase, although I know you dont need one.
Old Jul 16, 2011 | 11:01 AM
thomas1976's Avatar
Car: 91 Trans am
Re: Holley TB
I'm shure you will be happy to start tuning with it, the stock TBI ECM was a big headache for me too.
Old Jul 20, 2011 | 09:55 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
Re: Holley TB
I bought the HOlley TB only cuz I got a good deal for it. I pretty much did everything u want to a 305 but heads. I have a LT1 cam and springs. I think it was a good change.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
