I have a problem with a gas line...
Car: 1992 Camaro RS
Engine: Was L03 305 TBI...now BB 454 :)
I have a L03 305 TBI...it's lightly modded, and I was putting a JEGS TBI spacer on my car yesterday. But when I was unscrewing the fuel lines from the back of the TBI unit, it twisted the line and snapped it in half, mangled it all to hell. I hadn't ever taken off the fuel lines before, and was just too forceful. I just don't know how to fix it. I'll try and upload pics tomorrow. I just don't know how to fix a break in the fuel line like that...I really don't want to replace the whole line, does anyone have any ideas on how to fix this?!?
Car: Corvette
Engine: 5.7
Re: I have a problem with a gas line...
You can make a new line pretty easy out of brake line from the parts store that has the correct fittings on it. Buy a tube bender which is cheap and bend it to match the old one, or hit up a junk yard and grab one off a car.
If it were me I would just make a new one. It is very easy to do if you can find the line with the proper fittings on each end already. You can fix it for about $20 or less.
Car: 1992 Camaro RS
Thanks, but I'm not doing so hot trying to fix this so far. Could you give me any other advice SinthetikIroc?
Engine: gone
Transmission: gone
Axle/Gears: gone
change the line it only goes from the tbi to the rubber hoses like 3 feet long. Go to the junkyard and pull the line off of another car and then install it on yours. boom! problem solved. Next time check here and we will all tell you the tbi spacer is damn near worthless
Car: Corvette
Engine: 5.7
Car: 1992 Camaro RS
I heard the spacer could help, alittle with some low end torque and better gas mileage....also the hard lines coming out of the TBI really lead to rubber ones?
Engine: gone
Transmission: gone
Axle/Gears: gone
well thier rubber with fittings on the end. follow them they come out of the TBI run down the intake, across off the engine. Thier are two rubber fuel lines there. Just pop your head and you'll see.
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
This is kind of funny ... I have a 91 although I'm sure its got the same fuel line setup...
Take a look at this picture of my engine bay and note the fuel lines coming from the rear of the TBI:
See the fuel lines going to the rubber lines. You wont have that red regulator chunk but same thing. Those lines are only about 3ft long.
Engine: gone
Transmission: gone
Axle/Gears: gone
your fuel lines have been modded a little bit but that is the TBI setup. That pic should get the OP where he is needed. good work
Car: 1992 Camaro RS
Yes, thanks everyone, hopefully I'll be able to get my Camaro back on the road now!!
Engine: gone
Transmission: gone
Axle/Gears: gone
Just remember when your working on car. take your time. If your not sure about something ask. it's better than doing unneccesary things and/or breaking stuff. Good luck with the repair and I hope you'll be
soon
soon Member
Car: 1989 Camaro RS
Engine: 305 TBI
Spraying old nuts and bolts with liquid wrench before removal is a good idea too. Let it soak a while too.
Car: 1992 Camaro RS
I guess I just didn't know my own strength hehe
Car: 1992 Camaro RS
Ok, can anyone help me out? I've looked through all the junkyards around me, none of the camaro's or firebirds had a L03 in them, and all the yards said they didn't think they had any vehicles with an L03 in them. So I can't get the lines of a junker... anyone got some lying around by chance?!?
Car: Corvette
Engine: 5.7
I am sure you can find somebody who has them. But without sounding like a dick, your making this so hard on yourself. Just go to the parts store buy a line and bend it up. It is so simple. IMHO if you cannot perform this task you probably shouldn't be repairing your car.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
If you weren't so far away, you could get the one I have. It's functional but has a few small dings in the supply line, and needs new o-rings. I wouldn't know how to package it, and I think you'd pay more in shipping than what I paid for the one I replaced it with. You could probably replace it with some braided line with the correct fittings.
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
If you have not fixed it yet...
Replacing the line is probably the best way but, there are adapters available to convert to an style inverted flare, to ss braided. The ss braided can be hard to work with if you have not done it before.
Just to let you know there are other options depending on your skill level...
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you still need these, I've got a pair of good solid OEM lines I could let you have for reasonable, but the size might make shipping spendy, I don't know they are light though. PM or email me your email address for pics or other info, Henry
92camaroJoe
Aug 13, 2015 06:07 AM
