Time to Finish...... 88 Iroc Z Project!!
Old Jul 21, 2011 | 02:59 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
Hey guys here is teh Engine bay I have been working on, going to clean up polish and fix. I want to replace many lines as I can let me know what you guys think so far.
Weekend warrior Car, Done everything you want to a V8 305 I think so far but heads.....
I have replaced everything upfront on the supsension I believe I needed to do, brakes etc..
full tune up, and oil change, tranny flush
I gotta drop the tank again and replace fuel pump... I was thinking walbro this time what you guys think??
Anyone know belt size for V-setup? Or do I gotta do the String Trick?????
Old Jul 21, 2011 | 03:03 PM
Car: 88 IROC-z
Engine: LO3 V8 305
Re: Time to Finish...... 88 Iroc Z Project!!
I want to replace all these Lines Im taking photos of, Please let me know what you guys have done, or Recommend. It is a Weekend Warrior, not a racer just yet. More for fun driving and show off.
Old Jul 21, 2011 | 05:32 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
have you fired it up yet?
Old Jul 21, 2011 | 07:48 PM
Car: 88 IROC-z
Engine: LO3 V8 305
Every 2 months I fire her up, but it was like 4 this time, and there is no fuel going to my injectors so I think the pump went bad again.as the tank is kinda empty
Old Jul 24, 2011 | 02:03 PM
Car: 88 IROC-z
Engine: LO3 V8 305
needs new fuel pump guys what do you recommend???
If I put fuel in the TB its starts on a dime, but then turns off.
just need to get a ncie fuel pump and then the vac lines.
Old Jul 25, 2011 | 09:14 AM
Car: 88 IROC-z
Engine: LO3 V8 305
Nobody can give any advice or help here? Ouch! thougth this is the place to be and get the help I am looking for.
Old Jul 25, 2011 | 10:14 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
As for the belt id say the string trick. id adjust the tensioner for the altenator to be about in the middle, then do the string and get a belt the same size this way you have some play in the tensioner incase its a little short or long. As for replaceing lines the fuel line is pretty easy, if you want you can get the line and bend it yourself. I cant tell what line you wana replace in the second pic.
Old Jul 25, 2011 | 10:17 AM
bigreed91's Avatar
Car: 1990 camaro rs
Id definetly pull some of them parts off though and clean em up or paint em one, like the entire top of the water pump being rusted could use some touch up, and the tb adapter looks like its completely rusted as well
Old Jul 25, 2011 | 10:41 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Run the WALBRO 190 LPH fuel pump or the 255LPH fuel pump, but some have complained of it overpowering teh regulator and the fuel return line not being able to keep up. For your engine the 190 LPH will be more than sufficient. But in any case I also have a stock TBI pump I pulled out of mine a month ago, when I upgraded. it works. I can sell it cheap, you'd just have to buy a new screen for it. (but all that work to pull the tank id really put a 100% brand new pump in there)
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
