10 sec to start
Old Aug 10, 2011 | 12:47 PM
ssor's Avatar
10 sec to start
Hi guys! I have a problem that I can't figure out! When I start my car, it takes about 10 second to start. It starts right after the oil pressure gauge start to rize. First I thought that it could be the fuel relay, because it looks like the backup circuit take the place of the relay. But when I look at my injectors during the 10 seconds of cranking, I can see fuel coming out of them. So do you think that the relay could be in cause even if I see fuel?
Old Aug 10, 2011 | 02:16 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 10 sec to start
you see fuel but do you see enough fuel. it sure sounds like your relay is faulty. around 20 bucks at your local parts store and 5 minutes to put on.
Old Aug 10, 2011 | 02:59 PM
ssor's Avatar
Re: 10 sec to start
and can I try with the fan relay to see if it is my problem before I buy a new one?
Thanks!
Old Aug 10, 2011 | 05:16 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 10 sec to start
I dont think they are the same but I could be mistaken. I guess you can compare the #'s on them and if they are the same then it should work.
Old Aug 10, 2011 | 05:28 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 10 sec to start
the fanb and fuel pump relays are the same. make sure you are getting the prime from the ecm to. im not using my fan relay. so i cut the connector wires and then plugged it back in as a spare if i ever need it. and have it mounted right next to the fuel one.
also there should be a red wire with a connector on it at the fuel pump relay. put power to that wire and then try to start it.
Old Aug 11, 2011 | 07:46 AM
ssor's Avatar
Re: 10 sec to start
Yessss I've try the fan relay, and the car starts perfectly!!!!!
Thanks guy!
Old Aug 11, 2011 | 11:05 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 10 sec to start
You welcome man. Glad to see someone actually comes back and says hey I fixed it thanks to this site!
Old Aug 11, 2011 | 07:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 10 sec to start
Basically, relays are relays (in the auto world). As long as the connectors match up (some relays are oval, some are square, some small, some large), they can be swapped for testing and such. There are rare cases where relays are higher amps (most standards are 30 amps, some are 40 or even 60 amps), but in this generation of car I think all are simple 30 amp SPDT relays.
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
EFR2000
Aug 18, 2015 08:54 PM
Winchester1094
Aug 18, 2015 10:23 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
