Code 23 92 camaro
Old Sep 3, 2011 | 11:31 PM
bigmike174's Avatar
Code 23 92 camaro
Need help keep getting a code 23.replaced both parts throtle sensor and manifold.reset comp and it keep showings up.any ideads thanks.gwt the 12 flashes so accoring to book ecm good and the code 23 flashes.
Old Sep 4, 2011 | 01:27 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Code 23 92 camaro
code 23 is intake air temperature sensor if it is unplugged it could cause this. do you have your air cleaner off?
Old Sep 4, 2011 | 11:31 AM
bigmike174's Avatar
yes i replaced both sensor it said to m8.reset comp but still flashes 23 driving me nuts hate this dam ses light.how do i check to see if i have power at the plug to the sensor and what should ther voltage be if i do?thasnks
Old Sep 4, 2011 | 11:32 AM
bigmike174's Avatar
i have the the air cleaner on but in my book it says its the sensor on top of the manifold where is the air sensor at?
Old Sep 4, 2011 | 02:13 PM
one92rs's Avatar
Car: SOLD!!!!!
if it is tbi and it is the factory air cleaner it is on the bottom of the air cleaner near the egr valve. if it is an aftermarket air cleaner and there is no sensor then you need to find the wires and install it. wires should be tan and black.
Old Sep 4, 2011 | 08:53 PM
bigmike174's Avatar
found the plug but have after market breather.why do i buy to plug the dam thing into???????????thanks m8
bigmike174's Avatar
*where*
Old Sep 4, 2011 | 09:14 PM
one92rs's Avatar
Car: SOLD!!!!!
i have an aftermarket air cleaner. i drilled a hole and mounted my air temp sensor in it and then plugged it in. go to the auto parts and ask for an air temp sensor.
Old Sep 4, 2011 | 09:30 PM
bigmike174's Avatar
Is this the part m8.looked it up at auto zone.
Duralast/Air Charge Temperature Sensor
For your 1992 Chevrolet Camaro RS 5.0L TBI OHV 8cyl
Price:
$15.99
Old Sep 4, 2011 | 11:34 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yes that is what it is
Old Sep 5, 2011 | 02:58 PM
bigmike174's Avatar
does it matter which wire goes to either terminal have black and tan wires but no connector to make sure i plug into right spopt before hot clueing them in
Old Sep 5, 2011 | 04:09 PM
bigmike174's Avatar
thanks for all the help was so sick of ses light and in no mauals or book i bought did it mention that sensor.thanks my fellow camaro m8s
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
apie2546
Aug 10, 2015 05:43 PM
antares57
Aug 6, 2015 07:47 AM
