fuel pressure gauge
Old Sep 26, 2011 | 03:17 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
fuel pressure gauge
installed a fuel pressure gauge with an electrical sending unit. on a tbi engine. I installed it on the inlet side of the throttle body that is the correct spot to put it correct?
Old Oct 3, 2011 | 11:01 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: fuel pressure gauge
no one knows?
Old Oct 3, 2011 | 11:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Anywhere upstream of the FPR close to the injector.
Old Oct 3, 2011 | 01:41 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I installed on the inlet side of throttle body so that'd be before regulator, so that is fine then?
Old Oct 3, 2011 | 05:25 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
That is were I would put it, too.
Old Oct 3, 2011 | 06:55 PM
one92rs's Avatar
Car: SOLD!!!!!
yes that is where i would put it also. the return side is just that. only the feed side to me would see the pressure since the return should see almost no pressure.
Old Oct 3, 2011 | 11:44 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah that is what I thought, thanks guys.
Old Oct 4, 2011 | 06:18 PM
one92rs's Avatar
Car: SOLD!!!!!
pics??? and you got a gauge without fluid correct?
Old Oct 4, 2011 | 08:59 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
electrical sender, i had a fluid filled gauge and it didnt work right, so I put the electrical sender and have a gauge inside the car now. I just switched from the 255 lph pump to a stock delco tpi pump, I am now going to hook up my mechanical gauge i use at work and see if it does not read 50 psi anymore. since everyone here said the stock return system would not keep up with the volume there and give me inconsistent pressure
Old Oct 5, 2011 | 07:10 AM
thomas1976's Avatar
Car: 91 Trans am
Looking forward to know if this was the issue. https://www.thirdgen.org/forums/tbi/...-question.html
Old Oct 5, 2011 | 10:52 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Can't say yes for sure yet. I need to put my other gauge in. I dont know if I trust the electrical gauge all that much! Other gauge being an inline mechanical for testing purposes only. I just need a consistent pressure so I can really get down on the tuning. I wanna see this beast roar. lol. I'll keep you all posted. (i also gotta change my intake gasket because I am losing a lot of oil and the plugs were oil fouled, and that has been like that since the intake/heads were installed so I am assuming the intake gasket is leaking because thier was a minor complication.
Old Oct 5, 2011 | 12:31 PM
thomas1976's Avatar
Car: 91 Trans am
I sure hope you get it dialed it, what heads did you go with?
The FP display in the car is goig to be practical, by under load testing.
Old Oct 5, 2011 | 02:50 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I got edelbrock centerbolt heads real cheap on craigslist 350.00 for the pair with some roller tip 1.52 rockers
I am not sure I understand your 2nd comment. practical by under load testing?
Old Oct 5, 2011 | 05:25 PM
thomas1976's Avatar
Car: 91 Trans am
Ok, so this is the 355 you PM'd me about.
Can look at FP during WOT, for exemple.
Old Oct 5, 2011 | 06:24 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
correct
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
