Anyone know GM HYD rollercam #s
Old Oct 26, 2011 | 05:47 PM
dragracer1586's Avatar
My machinist has this cam that he said thinks came out of a Caprice Police car
Here are the #s GMPT BC 17...242
BC241
Looks strange to me as the nose where the cam gear goes is steped and it has a hole drilled in the center that is deep into the cam..It also does not have a lob for the fuel pump...
Thanks for any help guys..
Old Oct 26, 2011 | 05:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Anyone know GM HYD rollercam #s
stock roller cams had a step to work with the block retainer and no fuel pump lobe becose it is a efi cam. the hole is for the optispark drive.
https://www.thirdgen.org/forums/tpi/...rt-number.html
Old Oct 26, 2011 | 11:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What kind of engine is this going into? You can use it in a roller block, but if its an older block w/o the provisions, forget it.
Old Oct 27, 2011 | 05:14 AM
Thanks for the info guys,, Im building a 383 for my truck and need lot's of tq,
to pull a trailer.
I have a 454TBI and a set of 083 heads and LT1 roller block..I was thinking of getting a roller cam from a Caprice as they were a heavy car and cam profile was different with more low end.
I will be getting a ELB from Rob and play with it with the engine that's in it now to get use to the program..
What is "Optispark"???Will this cam work with out it ??
Any help you guys have will be appreciated...
Old Oct 27, 2011 | 05:55 AM
Anyone have the spec's for that cam???
Old Oct 31, 2011 | 04:03 AM
Car: 88 Camaro SC
Engine: SFI'd 350
I dont know the specs offhand. I think its larger than the stock cams, but not as big as the LT4 cam.
The opti-spark was just the ignition system used. The cam will work fine provided you cut the dowel pin to the correct length.
Edit: can your machinist measure the I/E lobe lift? That may at least give some clues as to what its specs are.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Dialed_In
Aug 20, 2015 01:45 PM
pwdbychevy
Oct 24, 2001 10:48 AM
BOWTIROC
Jan 19, 2001 09:09 PM
Paul Riccioli Jr
Oct 20, 2000 09:27 AM
