idle problems
Old Nov 3, 2011 | 08:32 PM
tzayoh's Avatar
idle problems
when my car idles cold it idles at like 1200 for a bit then it will go down and idle smooth between 600 and 900 depending on if in gear or park/nuetral. if i sit to long in traffic (dont know if its running warmer than normal because temp gauge is not hooked up) it will begin to idle around 500 and start to miss a bit and sometimes die if i cant start driving.
replaced my MAP sensor and my CTS, timing cant be to far out, im kinda stuck. any ideas?
Old Nov 5, 2011 | 12:18 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: idle problems
The idle speed adjustment is normal when the car is cold and it's warming up. I'm not sure what the issue is with the missing and dying though...
Old Nov 5, 2011 | 12:30 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Re: idle problems
Check fuel pressure, should be between 9-13PSI. Thats always a good starting point.
Old Nov 5, 2011 | 02:42 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: idle problems
Could be 1,000 things, mine did this when I rebuilt my my Throttle Body and threw off my TPS, you could check ur TPS too.
Old Nov 5, 2011 | 11:40 AM
tzayoh's Avatar
Re: idle problems
thanks guys, i guess ill just work my way down the line, can you test your TPS or do you just have to replace it and see, also where is it located
also how do i check fuel pressure, the only time ive ever had this problem was on a carb car and it just wanst pumping at all lol
Old Nov 5, 2011 | 09:25 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: idle problems
you can check your fuel pressure on the the fuel line that runs into your throttle body, u gotta have a TBI adaptor, there is a thread on here somewhere with pics and everything.
For the TPS it is located on the side of your TBI, you can check to make sure its gettin the right voltage ( cant remember what it is), if you take it off dont spin the plastic wings on the inside, that thing is calibrated... you can bring it into a shop and ask em to check the calibration on it ( I would find out who has the capability before removal). If you bought one its gonna be about $25 and its pre calibrated.
If you dont wanna wast all kinds of money doing the "trial and error" method, id just bring it to a shop if you cant easly find the problem.
Good luck
Old Nov 6, 2011 | 09:31 AM
tzayoh's Avatar
Re: idle problems
i may have to resort to that, i just always find i do a better job than they do...lol...but i hate electrical anything, i realy only got this car because it was the only one running on craigslist, and it does get me where i need to be, just has small things wrong with it, all electrical.
i was thinking, had i had this speratic idle problem on one of my old cars (no sensors or electrical bullshit) i would kinda be leaning t'wards a bad timing chain (or belt on this, not sure??), like maybe as the car heats up the chain expands a little and allows my timing to get a little sloppy. if its only a little out at running temp that would explain why i dont notice the miss on the gas only at a low idle. but again, ive never even had a bad timing chain before or had to work on a car with one, so im not sure if this is a plausible symptom
Old Nov 6, 2011 | 11:29 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: idle problems
I would start with running a OBD 1 scan on the ECU to see if there are any faults as a first step in trouble shooting any electrical.
Old Nov 6, 2011 | 07:49 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Re: idle problems
Can anyone show me a link to a TPS Sensor that if I was going to buy one thats the one i need. Everytime i look one up there are 2 different things that come up. Im not exactly sure what i need to buy.
Old Nov 6, 2011 | 09:35 PM
tzayoh's Avatar
Re: idle problems
wouldnt the OBD only pick up something that a sensor says is bad though?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
