vortec?
Old Dec 19, 2011 | 01:18 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
vortec?
Did the 1995 suburben 1500 come with the vortec motor?
Old Dec 19, 2011 | 01:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: vortec?
The L31 was introduced in 96 -2000
Old Jan 5, 2012 | 08:32 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: vortec?
Is the l31 a good engine? I have the option to buy a 96 l31 out of a suburban and I also have th option to buy a lt1 from a 95 camaro. I can't decide which to go becausidk which can an will make power better and easily. My plans are for 500 rhp. Any input?
Old Jan 5, 2012 | 08:43 PM
ex-x-fire's Avatar
Re: vortec?
First find out if its a 1500 or 2500 suburban, the heavy ones sometimes had low compression pistons (block will be a 4 bolt main), vortecs have great heads(very similar to lt-1 heads in flow & chambers) & roller cams. Are gonna run a carb or efi. 400hp is a realistic number for a 350, if you really want 500hp, then think about building a 383.
Old Jan 5, 2012 | 09:34 PM
Engine: L31 350
Re: vortec?
its 1500 i believe, 2 wheel drive i know that. iv thought and might do a 383 to get that number, idk i have alot of plans for the engine, and i want to go efi. i cant stand carb or throttle body and plan on converting it to something else if i do get it. i just cant decide which engine is better and will be better in the long run. like i said i want alot of power and i know what i can do to an lt1, idk what i can do to a vortec
Old Jan 22, 2012 | 12:32 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: vortec?
Go vortec. Its less hastle with some things. LT1 has reverse cooling among other things. They have the same power potential. 500hp 350 will require a power adder.
Old Apr 4, 2012 | 09:12 PM
Engine: L31 350
Re: vortec?
come to find out the truck is a 2500, what all does this change? is it better or worse?
Old Apr 4, 2012 | 10:21 PM
tman92's Avatar
Car: 1992 Camaro RS
Re: vortec?
Both 1500 and 2500 will be the same base on the 350. Difference will come in the programming in the computer and the cam will have slighty different specs to give it better torque rating. My 98 Z71 is that way.
Old Apr 4, 2012 | 11:06 PM
Engine: L31 350
Re: vortec?
well i noticed above it said the heavier trucks had low compression pistons
Old Apr 4, 2012 | 11:19 PM
tman92's Avatar
Car: 1992 Camaro RS
Re: vortec?
If it is a 8000lb plus truck then it is possible as some trucks with the higher gvw got the 3500 350. Usually the higher gvw vehicles with lower compression pistons had the 4.56 geared rearend.
You can also call the dealer with the VIN and get more info on it if you have it.
Old Apr 4, 2012 | 11:25 PM
Engine: L31 350
Re: vortec?
i can ask my buddy, it came out of his truck because hes tossing an ls into it lol. what are some good cams for these? it has 130K on it and either a bad head or intake gasket so im thinking of doing just a rebuild with maybe a cam upgrade but i dont know what to buy, iv never messed with an engine like this before
Old Apr 7, 2012 | 01:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: vortec?
ALL 350 vortec engines had the same piston and cylinder heads. Same 9.4:1 compression. This includes the ones used in heavy P30 chassis. The TBI engines are the one that had a lower compression ratio, forged crank, intake rotators, and piston oil cooling jets.
Old Apr 7, 2012 | 05:15 PM
Engine: L31 350
Re: vortec?
This engine is tbi
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
