Oil Switch location
Old Dec 30, 2011 | 09:33 AM
-LateNite89-'s Avatar
Oil Switch location
I'd like to replace the bad oil pressure switch. I'm tired of looking at the gauge constantly bounce around and drop to zero even when I'm driving and I'd rather not pay xxx amount of dollars to get it replaced if I can do it myself, but I don't know where it is. Anybody have a pic or tell me where its located at? Thanks.
Old Dec 30, 2011 | 11:03 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Oil Switch location
Top of the engine behind the distributor closer to the drivers side.
Mark.
Old Dec 31, 2011 | 05:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
On a later model like yours it's probably sticking out sideways on the lower block just above the oil filter housing
Old Jan 2, 2012 | 09:37 AM
RSCAMAROGUY91's Avatar
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
Yeah it's right above the oil filter location. Some quick advice...Don't worry about getting the special socket to take it out, because you can't get it in there, so I ended up having to having to use a pair of adjustable pliers to get it out.
Old Jan 2, 2012 | 11:53 PM
torque_is_good's Avatar
flare wrenches work wonders
Old Jan 3, 2012 | 08:31 PM
Yeah those would've came in pretty handy, HAHA.
Old Jan 3, 2012 | 11:14 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it was in both locations, depending on exact year make model what the engine is for or from exactly
some vehicles had one at the back top of block and also driver side in rear right above oil filter just in front of the the bellhousing flange
the early and mid 80s engines
in the F and B body cars, mostly
most had the one at top rear of block near distrib though,. and not the one near oil filter
have fun!
Old Jan 4, 2012 | 05:28 PM
have fun!
Yeah they did have both. The easiest one to change on the Camaro/Firebird's are the ones that are on top of the engine.
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
