excessive fuel consumption problem
Old Jan 9, 2012 | 02:40 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
Hey guys. I have a 90 firebird 305 tbi and for some reason I'm getting under 9 mpg. I tried searching for an solution on here but haven't seen anything yet. And I really need help
Old Jan 9, 2012 | 03:02 PM
Ronny's Avatar
Re: excessive fuel consumption problem
CE light? codes?
possible coolant sensor telling the ECU it is -40dF.
Old Jan 9, 2012 | 08:07 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
Ok here's the codes I got. It's about 20 degrees outside today so idk if that would trigger any of these.
15.low temp at coolant sensor
23. Low temperature at manifold air temperature sensor OR Throttle position sensor error
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
44. Oxygen sensor lean
So this means I need to replace the coolant temp sensor right? And if so, which one. I know when I used to work on Honda's they would have two but idk if these cars do as well.
Old Jan 9, 2012 | 08:17 PM
one92rs's Avatar
Car: SOLD!!!!!
i think you have a vacuum leak at the throttle body. and have you checked coolant level. i was getting really bad fuel mileage before and it was the coolant sensor.
Old Jan 9, 2012 | 09:00 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Speaking of vacuum leaks, did you finish that IAC mod for the TB?
Old Jan 9, 2012 | 09:12 PM
one92rs's Avatar
Car: SOLD!!!!!
you know what i never did that. bought a bunch of other parts that i still have to get finished.
Old Jan 9, 2012 | 09:30 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
How do you check for a vacuum leak?
Old Jan 10, 2012 | 06:25 AM
ex-x-fire's Avatar
Make sure your engine is getting up to proper temp. The coolant temp gauge should be close to the middle, not hanging near C. This really impacts fuel mileage. Cooler running is not better for good mpg.
Old Jan 10, 2012 | 06:38 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Spray areas you think might be leaking with carb cleaner. You'll know when you hit it because it'll cause your engine to idle higher
Old Jan 10, 2012 | 10:06 AM
Ronny's Avatar
check the sensor with a volt meter....If you suspect it is 25 years old I might just replace it....
Old Jan 10, 2012 | 04:19 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
Will do both. I get paid Thursday so I'll post up if it worked then. That's to all.wish me luck
Old Jan 10, 2012 | 09:48 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
Ok so I checked for vacuum leaks and found none (which I suspected cuz I just cleaned the whole throttle body and replaced all the gaskets) then I replaced the coolant temp sensor,dizzy cap and rotor,spark plugs and wires(since the car has been sitting for 8 years OUTSIDE),started her up cold no problem(which is a first for this car) AND no ce light! Took her for a spin to the store and she's running better than ever. Thanks everybody!
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
