Leaky headers?
Old Jan 26, 2012 | 09:39 AM
Mastiff's Avatar
Leaky headers?
I'm wondering how badly leaky headers could mess up the TBI system due to corrupt O2 readings? This is just a theory, but my system seems to always want more fuel at idle and barely accelerates when cold. My theory is that maybe the headers aren't tight when cold, so some air is getting in. I have no other reason to suspect this though; there is no noise from the headers like a bad leak. Is this plausible?
Old Jan 26, 2012 | 12:10 PM
ex-x-fire's Avatar
Re: Leaky headers?
If you dont hear a leak, then I would look elsewhere for the problem. Like weak fuel pressure.
Old Jan 26, 2012 | 01:37 PM
Mastiff's Avatar
Re: Leaky headers?
But why would my fuel pressure get better once the vehicle is warmed up?
Old Jan 26, 2012 | 01:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Leaky headers?
It doesn't even use the O2 sensor when it's cold.
Old Jan 26, 2012 | 01:54 PM
Mastiff's Avatar
Re: Leaky headers?
The bad time is after it goes closed loop, before it is fully heated up. And my O2 sensor is heated.
Old Jan 26, 2012 | 02:35 PM
Ronny's Avatar
Re: Leaky headers?
No heat to TBI unit? Thermac? Fuel not atomizing properly?
Old Jan 26, 2012 | 02:52 PM
Mastiff's Avatar
Re: Leaky headers?
Have all the factory stuff.
Old Jan 26, 2012 | 02:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Leaky headers?
Does it still work?
What's your coolant temperature like while it's misbehaving?
Old Jan 26, 2012 | 07:38 PM
Mastiff's Avatar
Re: Leaky headers?
Does it still work?
Yeah, I think it works. The thing runs okay, not great, until it goes closed loop, then it won't accelerate for anything (stumbling, etc.) until around the time the thermostat opens. I can't remember what that is in degrees, but I can see it on my temp gauge because of the sudden slight drop when it opens.
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Bigold4x4
Sep 28, 2015 05:21 PM
