cfi help please?
Old Mar 1, 2012 | 09:26 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
cfi help please?
Quick history- 83 T/A with crossfire fuel injection. I just recently change the fuel pump and when I tried to start it, fuel shot out of the top of the front throttle body. I guess the more info the better..the car was running fine until the fuel pump died and it sat for about 2 years, not sure if this is a factor.
I'm unfamiliar with throttle bodies and I'm not sure where to start. Any advice on what to look for would be amazing. Also any recommendations on books over cfi would be helpful. I have the haynes repair manual and the Pontiac Service Manual but neither really seems to go in depth on the crossfire.
Thanks in advanced
Old Mar 2, 2012 | 02:42 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: cfi help please?
It sounds like either the rubber diaphragm on the fuel pressure compensator or an o-ring on the fuel injector pod failed.
If it hasn't ever been done in the last 30 years it would be a good idea to install a new gasket kit in the throttle bodies. Also check the throttle shafts for wear and get bushings installed if they're loose. This will cause rough idle and make it impossible to properly balance the throttle bodies.
Old Mar 2, 2012 | 12:13 PM
Car: 1983 Trans Am
Engine: Lu5
Ok I will try that, thank you for the advice
firehawk66
Sep 27, 2003 09:06 PM
XFire83
Dec 12, 2001 04:24 AM
Demon Z28
Jul 21, 2001 10:32 PM
Benji
Jul 1, 2001 11:41 AM
1982cfi
Jun 27, 2001 10:54 PM
