Stupid question
Old Mar 12, 2012 | 08:06 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Stupid question
This may be a stupid question, and I hope I dont get flamed too bad...LOL!!!
Can I remove the computer from my car and still use the throttle body? Also, what about the transmission? Will it work right without the computer?
I was thinking of using a carberator if the computer can be removed. I know that the computer controls a lot of stuff.
If I remove the computer:
Can I use a carberator?
Will the tranny act right?
Will the cooling system work right?
What all does the computer actually do?
I am new to all this computer stuff, and would really like to get rid of it if possible.
Old Mar 12, 2012 | 08:18 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Stupid question
if you remove the ecm you will have to go carbed. the tranny lock up will no longer work either. nor will the distributor. go to the carb section and read.
Old Mar 12, 2012 | 08:54 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Stupid question
and you'd have to remove the throttle body.
lose ecm.
need to rewire torque converter lock up
HEI distributor
cooling system will work right, except fan? would probably have to wire that up different if im not mistaken.
Old Mar 12, 2012 | 09:15 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Stupid question
1. if you are tbi the fan will work as long as the wiring to the passenger head is left intact.
2. tbi will not work
3. you will need an hei dizzy. you small cap one will not work.
4. you will need an intake for a carb.
5. tranny lock up will no longer work.
6. you will need a return style external regulator to cut down fuel pressure
7. unless 86 or older you will no longer pass inspection
Old Mar 12, 2012 | 09:41 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: Stupid question
One good thing is around here it is 96 snd older!!!
Old Mar 12, 2012 | 09:48 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: Stupid question
Has anyone put a blower on a 305tbi car before? If so, what were the results?
Old Mar 12, 2012 | 10:03 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Stupid question
Old Mar 12, 2012 | 10:21 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Stupid question
im sure the blower has been done. if you want to buy a blower go ahead and a buy a 350 engine also...makes more sense.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
