Injector nightmare
Old Mar 28, 2012 | 04:20 PM
system155's Avatar
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
Injector nightmare
Ok os I have a 89 305 tbi and I can't get the injectors to start firing and I know that I have fuel presser all the way up and I changed ingenious model and the ecu need help with this
Old Mar 28, 2012 | 04:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Injector nightmare
do you have loss of spark as well?
Old Mar 28, 2012 | 05:38 PM
system155's Avatar
No I still have spark
Old Mar 28, 2012 | 05:44 PM
Engine: Lb9
Transmission: M20
I think 89 in tbi was the first year of vats, that would disable the injector pulse.
Old Mar 28, 2012 | 05:45 PM
one92rs's Avatar
Car: SOLD!!!!!
do you have power to the injectors. there are two fuses under the dash for them. the ecm only applies ground to them.
Old Mar 28, 2012 | 05:58 PM
system155's Avatar
No I already bypassed that when I first got the car
Old Mar 28, 2012 | 05:59 PM
system155's Avatar
Yeah I got power the there just not pulsing
Old Mar 28, 2012 | 06:16 PM
one92rs's Avatar
Car: SOLD!!!!!
the the ecm is not seeing rpm or a spark while the engine is turning over.
Old Mar 28, 2012 | 07:15 PM
system155's Avatar
how would you go about checking that??
Old Apr 1, 2012 | 08:13 PM
Schurkey's Avatar
First Guess: Not ingenious enough.
Doesn't HAVE to be a wiring/computer problem.
I swapped throttle bodies on my pickup in the process of diagnosing a Code 44. The replacement throttle body only sprayed fuel from one injector. Had power to both.
Turned out that the fuel injector was stuck. Ran the engine a few minutes longer, and it began to spray. Has worked fine ever since.
I'd consider tapping on the injector housings in the (probably futile) hope that they're varnished up.
Old Apr 20, 2012 | 05:45 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Could very well be the ignition control module again, Don't trust just one part from places like auto zone, try another! I went through 4 one time to get a good one
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
