stock fuel pump
Car: 92 camaro RS
Engine: vortec 350/396
stock fuel pump
anyone have experience doing a fuel pump on a third gen? ive done plenty on my 4th gen but I cut a access panel behind the seats. so I figured itd be the same measurements on the 3rd gen... nope. do you have to drop the tank on these?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: stock fuel pump
dropping the tank is pretty easy -did mine back in '93
and again last year,did cheat a little back in '93 though:
not saying i recommend this,but back then i couldn't
seem to get the filler neck through without bending it
so cut the neck about 3"back from the cap and rejoined
the halves with a chunk of hose after tank reinstalled
-this made the 2nd drop last year real easy...Many here
have reported dropping the tank with no problems or
modifications at all,so possibly later models have more
clearance or i just was not getting the tank in the
right position in '93
BTW the hose that i found
was perfect for the filler neck was a section of
intercooler hose from a renault fuego turbo
BTW the hose that i found was perfect for the filler neck was a section of
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Car: 92 camaro RS
Re: stock fuel pump
I did a search and found a post with pics. ppl said cut the lines and reconnect them with compression fittings. but im carbing my 92 and I am pulling the pump to remove it and install a fuuel hose to the bottom of the tank. sry that ppl get so frustrated over the internet. it didnt even dawn on me to do a search
Car: '82 z28
Engine: L83 5.7
Re: stock fuel pump
what kind of pump is in the tank now?-if it's a stock TBI
pump that is a turbine pump and fuel will flow through
it with out the pump running-can just leave in place
and draw fuel through it.If its a TPI pump that will need
removed as those have roller 2nd stage and do not flow
well inactive.
well inactive.
Car: 92 camaro RS
Re: stock fuel pump
its tbi. I cut a access panel and took the lock ring off the pump and pulled it up a little cuz I havent cut the lines yet and the pumps all rusted up. so im gonna remove it and see wats going on in there.
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
