TBI Blues
Old May 19, 2012 | 05:38 PM
peej07's Avatar
Car: 89 RS
Engine: 305 TBI
Axle/Gears: 2.73 1 wheel peel
TBI Blues
Hey guys I'm hunting a ghost. I recently moved to Georgia and they require emission checks. So I've started replacing items that did need to be replaced. TBI base gasket, PCV, some vac lines, cap rotor plugs and wires, and a new EGR valve. Now the funny thing was I was chasing a slight mis fire at idle (Which is still there). The car ran great before I started all this and with each repair it seems to run worse! The latest being the EGR valve, I have a wonderful little stumble right off idle now and it's madening . Could a possible exhaust manifold leak cause this lean mis fire or should I be looking at something else. Thanks
Old May 19, 2012 | 06:37 PM
Schurkey's Avatar
Re: TBI Blues
How do you know it's a lean misfire? What are your O2 readings? What are the fuel trim numbers?
Idle air bypass clean? Idle air control working? Correct PCV valve installed? Computer getting correct engine coolant temperature reading from sensor?
Exhaust manifold leak would more likely cause a rich mixture. Air entry to the exhaust stream would show false excess O2 in the exhaust--lean mixture = rich command.
Old May 20, 2012 | 01:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: TBI Blues
weak fuel pressure can cause the off idle stumble-my
crossfire did that when the fuel pump was going bad,
pump replacement/upgrade completely cured the
stumble.
Linson
Sep 21, 2015 01:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
