Code 54
Old Jun 8, 2012 | 09:55 AM
joebeagle's Avatar
Car: 1991 RS Convertible
Engine: 5.0L
Transmission: Standard
Code 54
During the week my 91 was running down i-95 fine when it cut out flat. Towed it home, changed the distributor cap, fuel filter. Check the spark, timing, fuel pressure, fuel relay. Made sure all the codes in the ECM were cleared out. Took it for another test drive, car ran fine the whole way. Second test drive i got about 2 miles and the car quit flat again, no warning. Code being thrown is code 54. Car tries to start, sounds like ****. Looking for suggestions, please!
Old Jun 8, 2012 | 12:42 PM
Ronny's Avatar
Re: Code 54
https://www.thirdgen.org/forums/diy-...fuel-pump.html
https://www.thirdgen.org/forums/tech...lp-please.html
Old Jun 8, 2012 | 02:07 PM
joebeagle's Avatar
Engine: 5.0L
Re: Code 54
Thanks for the advice. I had already seen those posts and tried their recommendations before I posted this myself.
Old Jun 10, 2012 | 01:58 PM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Code 54
I had the same issue just a few days ago, where my car was very hard to start and also throwing code 54, I swapped relays for the one next to it (I believe it's the horn relay?) and the problem went away, so I'm pretty sure the relay is bad.
Old Jun 10, 2012 | 07:41 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Code 54
the one you swapped it with is the fan relay. the two relays on a 92 are fan and fuel pump.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
