TBI Adapter Help!!
Old Jun 20, 2012 | 09:09 PM
jollythought's Avatar
Car: 1983 Trans Am
Engine: Lu5
Transmission: TH700R4
TBI Adapter Help!!
Car info: 83 T/A CFI
Problem: Broken TBI to fuel line adapter
I cant seem to get an exact measurement on the correct size of the adapter, and I was hoping someone could provide insight on the correct measurements and maybe a site where I can buy them.
The pictures are the adapters I currently have and the stock fuel line they connect to
Old Jun 20, 2012 | 09:12 PM
Car: 1983 Trans Am
Engine: Lu5
Re: TBI Adapter Help!!
Here are the pictures
Attached Thumbnails TBI Adapter Help!!-dsc00229.jpg   TBI Adapter Help!!-dsc00230.jpg
Old Jun 20, 2012 | 10:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
is a 220 the same?
ACDELCO 17111462
or russell
-6 to 12mm x 1.25 O-Ring Seal (Endura) 640800
-6 to 12mm x 1.25 O-Ring Seal (Black) 640803
-6 to 14mm x 1.25 O-Ring Seal (Endura) 640810
-6 to 14mm x 1.25 O-Ring Seal (Black) 640813
Old Jun 21, 2012 | 06:21 AM
Car: 1983 Trans Am
Engine: Lu5
The AC Delco part looks like it would work but ebay is saying it is not compatible. The Russel GM TBI Fittings might work, but I would then need an adapter to connect both male ends. But I do believe the TBI is 12mm x 1.25. And the fuel line I am going to be using is the fuel pressure assembly from DCS,Custom bent 3/8 316 polished stainless tubing, -6AN fittings, fuel block and 15psi gauge, if that helps.
Old Jun 21, 2012 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try the JY, look for FWD 4-cylinder TBI cars and RWD trucks. IIRC, they use the same basic TBI unit.
There is a thread here where we measured those and the 2-bbl TBI ones.
RBob.
Old Jun 21, 2012 | 07:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Post # 24 has the thread size:
https://www.thirdgen.org/forums/tbi/...e-cfi-car.html
Also note that apparently the CFI fuel lines are the older SAE 45* flare, while the newer TBI stuff uses a Saginaw fitting on the fuel line.
RBob.
Old Jun 21, 2012 | 04:29 PM
Car: 1983 Trans Am
Engine: Lu5
Thank you, I was looking over that thread but I wasnt sure where to find them or if i could get new adapters. I guess I will be going to the junkyard this weekend
Old Jun 23, 2012 | 04:53 PM
Car: 1983 Trans Am
Engine: Lu5
So I was able to find a piece that will fit, the only difference is that it is slightly smaller. Will this affect the fuel flow and cause the engine to not run right? It came from a TBI return line
db057
Jan 10, 2020 08:55 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Bigold4x4
Sep 28, 2015 05:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
BLK87Z
Sep 18, 2015 11:29 PM
