Rough Idle When Warm
Old Jul 18, 2012 | 01:27 PM
maxjivi05's Avatar
Okay, I have a 1991 Camaro RS with a 350 put in it.
when my car warms up if I stop at a light I have to hold gas and break so it will not stall out, but when cool it runs fine.
I've replaced ICM, Cap, Button, Pickup & Ignition Coils.
When I have $ I'll replace plug & wires.
what else should I check?
TPS? what to check for?
IAC?
I just want this fixed I've went broke buying and getting it running.
Old Jul 19, 2012 | 12:22 PM
ex-x-fire's Avatar
Re: Rough Idle When Warm
Try to disable the egr valve by plugging the vacuum hose that goes to it, then drive it to see if it stalls.
Old Jul 19, 2012 | 11:31 PM
dahoyle's Avatar
Sounds the same as an issue I had. I almost never found it.
http://www.fullsizechevy.com/forum/g...02009-fpr.html
Not saying that's your problem, but it sure as hell fixed my idle surge.
Old Apr 7, 2013 | 06:01 AM
leo27030's Avatar
Car: 91 Camaro RS
Engine: 3.1 L V6
Transmission: Automatic
Mine started that about a month ago it runs fine when cold , but as soon it warms up it idles down then up and after doing that a while it stalls and won't start for about 4 hours . I've replaced so much on it and nothings helped . here's what all I've replace so far
IDLE AIR CONTROL VALVE
FUEL PUMP
FUEL PUMP STRAINER
FUEL FILTER
IGNITION COIL
OIL PRESSURE SWITCH
DISTRIBUTOR
DISTRIBUTOR CAP & BUTTON
IGNITION CONTROL MODULE
EGR VALVE
MUFFLER
AIR FILTER
AIR CHARGE TEMP SENSOR
ECM COMPUTER
Old Apr 7, 2013 | 07:46 AM
ex-x-fire's Avatar
Leo, just because you replaced the egr valve doesn't mean its getting vacuum at idle. The egr solenoid might be letting vacuum through when it shouldn't, like at idle.
Old Apr 7, 2013 | 07:47 AM
one92rs's Avatar
Car: SOLD!!!!!
is there no check engine light on? is there a way to get someone to hook to it to see what the 02 sensor is reading? what are the fuel pressures? do you have an intake leak? grounds?
Old Apr 8, 2013 | 02:30 PM
leo27030's Avatar
Car: 91 Camaro RS
Engine: 3.1 L V6
I checked it out the egr is working good but I shined a flashlight under the intake plenum the see the injectors and one of them has the has bare wire in 3 different places but not touching anything , but what's really strange is it has to warm all the way up to act up and yesterday when I let it run till the radiator fans kicked on it didn't act up except for missing every now and then and when I turned it off and then it would start and die and did that a few times then started u and ran with out acting up other than missing every now and then .
Old Apr 8, 2013 | 02:37 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
You could check the Air Flow Metter AFM.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
