Oxygen sensor problems
Old Oct 2, 2012 | 08:45 AM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Last summer I installed a new oxygen sensor, after learning how to data log I found out that the sensor is staying in open loop, my question is would a bad coolant temp sensor lead to faulty o2 sensor readings? Because the temp is reading abnormally high
Old Oct 9, 2012 | 08:43 PM
xstang77's Avatar
Re: Oxygen sensor problems
yes it would, if your ect sensor is bad it wont ever let the car go into closed loop which will throw your fuel trims all over. when mine was bad i had a high idle and bad gas mileage
Old Oct 10, 2012 | 07:18 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I would check the sensor with your datalog, I kept burning up Bosch sensors for some reason, threw in an ntk and haven't had a problem since, when I looked at the graph it would stop banking properly and it kept giving out a lean signal so I was dumping fuel like crazy
Old Nov 6, 2012 | 11:24 PM
Teal88's Avatar
Car: 1991 RS
Engine: The 305
Transmission: Upgraded 700r4
Axle/Gears: 3.42 Limited Slip
Hey just something to think about....have you checked the ground for the 02 sensor on the wire harness?
I have the ebl system and noticed one day my 02 sensor flat lined for *seemingly* no reason...Nothing could get it to run the expected and normal cycle. So, I "upgraded" to a heated o2 sensor, wired it up, and then noticed that nothing changed. I was still getting that annoying flat line. I cut the specific ground wire for the 02 sensor coming off of the ECM wire harness and grounded it to the body. The O2 1 sec lean/rich cycle started right up and I had an excuse to tell the wife that I needed a heated sensor...it's a win win.
The threads necessary to figure out the ground issue for the o2 sensor can be found on this site via search. It's been a while and I don't want to mislead you.
Old Nov 7, 2012 | 01:02 AM
Engine: 305 LO3
i havent driven the car in a few months due to school, and now that november is here the weather is turning to ****, and probably wont have the car out again, might have time to give her a nice clean up but the snow will be here and the cruising season will be gone. over the winter i plan on rebuilding the front brakes, and will hopefully get to diagnosing the situation, its times like this i wish i didnt live in the northeast
db057
Sep 4, 2015 07:57 AM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
beast94
Aug 20, 2015 06:44 AM
