got fuel but won't fire ...
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
ok i got fuel but no fire . i'm thinking the control module but i'm wondering if it could be anything else . any iseas will be greatly apreciated ...
Car: check
Engine: check
Transmission: check
Re: got fuel but won't fire ...
Can unplug the 4-wire connector at the distributor to prevent the ECM from firing the injectors (so it doesn't flood). Then test for spark at the coil & plugs.
Be sure to change the flag for the MAP sensor in the calibration. If set for 3-bar and using a two bar it will likely flood.
RBob.
RBob.
Engine: l98 tpi
Axle/Gears: 2.77
thanks rbob , i had to replace the controle module a couple summers ago . is there anything else besides the control module that will cause these symptoms ? thanks for helping
Car: check
Engine: check
Transmission: check
Assuming the no-start is due to a lack of spark, coil, cap, rotor, & ICM are the ones to look at.
RBob.
RBob.
Engine: gone
Transmission: gone
Axle/Gears: gone
normally don't just lose compression.
you sure you have fuel all the way to injectors and out of them?
more than likely your culprit is the ignition control module. i carry a spare in my car at all times.
Engine: l98 tpi
Axle/Gears: 2.77
my fuel pressure gauge shows 10 after priming . this problem comes an goes . one day it won't start .leave it alone a day or two an go try an it fires right up . i started it mulitpule times for four days straight an on the fifth no fire . i had this happen once before a couple years ago an it turned out to be the controle module . but keep throwing otrher ideas at me just incase . it's been two bad weather to play with the car the past few days but hopefully monday i can test a few things
Car: check
Engine: check
Transmission: check
Could also be the two-wire pigtail between the coil & ICM. The wire likes to break inside of the insulation where it exits the coil connector.
RBob.
RBob.
Engine: l98 tpi
Axle/Gears: 2.77
ok i started checking for spark at the number one plug . i have a faint flicker of a spark . so that would be the coil then instead of the icm correct ?
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I assume plugs are gapped correctly .. So .. I'd say got to auto parts store and buy a 10-15$ multimeter if u don't have one .. Then u can check parts like coils tps sensors o2
Sensors etc. usually u can find out what the voltage should b on the web ... Trust me a multimeter can save u ALOT of $ over the years instead of throwing parts at cars with no luck which I also did for a few years as well .
Engine: l98 tpi
Axle/Gears: 2.77
as soon as i get a couple nice days i'm gonna change the plugs an see if maybe i've just fouled the plugs running it so rich
Engine: l98 tpi
Axle/Gears: 2.77
i checked the spark coming from the coil an it looks like a 4th of july sparkler . any body have any ideas before i start throwing parts at this biotch ? lol
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
92camaroJoe
Aug 13, 2015 06:07 AM
