Advice on porting LO3 intake
Old Feb 26, 2013 | 02:16 AM
nando5's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Transmission: 700R
Axle/Gears: 3.42/open (4th gen)
I want to know if its worth porting the stock lo3 intake manifold?
and if its actually going to gain any hp or torque?
Thanks in advance.
Old Feb 27, 2013 | 01:46 AM
Schurkey's Avatar
Re: Advice on porting LO3 intake
Thanks in advance.
First Guess: Not worth the effort.
Old Feb 27, 2013 | 11:05 PM
nando5's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Transmission: 700R
Are you talking from experience?
Or is it just your guess because its an lo3 intake? lol
Just want a little more gain with the full exhaust and headers.
Old Feb 28, 2013 | 01:13 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Would have to see it up close to see if you can even get to all the passages. Unless you can its not worth it. Is it all stock even warranting it?
Old Feb 28, 2013 | 06:46 AM
ex-x-fire's Avatar
Get a performer intake & tbi adaptor.
Old Feb 28, 2013 | 11:12 PM
nando5's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Transmission: 700R
Will it be able to take EGR?
I dont want Smog shops making it a big deal because its missing EGR.
With this new star testing here in Cali its making it harder to pass. I barely passed this year.
Old Mar 1, 2013 | 05:56 AM
ex-x-fire's Avatar
Oh, thats right your in cali. Your only other option other then stock is the eddy tbi intake, it is smog certified.
Attached Thumbnails Advice on porting LO3 intake-wmdsc01503.jpg   Advice on porting LO3 intake-350-3704.jpg
Old Mar 1, 2013 | 09:08 AM
Axle/Gears: 4.11
They willl Im out here also
If you get one bring it over if it looks viable..
Old Mar 1, 2013 | 12:23 PM
Schurkey's Avatar
You can barely pass smog test, and you're attention is focused on modifying the engine MORE?
It might be better to figure out why the engine is emitting excess pollution, and repair that, first.
Old Mar 1, 2013 | 05:03 PM
nando5's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Transmission: 700R
@cuisinartvette Yeah Ill see if i decide to get it. Most likely i will.
My smog guy said that my car is running clean but with this new star testing stuff they are making it harder to meet requirements because they want all old cars out of the streets already. He told me to just replace my old cat with a new one and that I should be good as long as my car is running good.
Last edited by nando5; Mar 1, 2013 at 05:13 PM. Reason: Miss spelled words, missing words
Old Mar 1, 2013 | 05:08 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm actually porting one right now just for the hell of it. There is a TON of material that can be taken out of this manifold. I'm porting this one to a 1205 gasket with more than enough meat for safety. The throttle bores can be opened up easily to about 51-52mm safely. I'll post pics of it tomorrow. Truthfully in my opinion it's not worth upgrading to the 3704 intake unless you port the hell out of it. I know from experiance as I used to own one that it can be safely bored out to 50mm.
Old Mar 1, 2013 | 05:18 PM
nando5's Avatar
Car: 1990 Camaro RS
Engine: 305 tbi
Transmission: 700R
Oh sweet let me know how that goes.
I might go with the performer intake and buy an adapter plate with it. I saw that they make one that takes EGR.
Old Mar 1, 2013 | 05:41 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The stock intake manifold on top of the LO3, is far from being a restriction.
I would immagine that if ported, it could work wery well on a 300-340 fwhp engine.
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
