fuel pump relay harness pinout ( wire colors)
Old 03-23-2013, 06:49 PM
  #51
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
Re: fuel pump relay harness pinout ( wire colors)
How would you go by repairing the fuel pump circuit if it shorted?
Old 03-27-2013, 11:38 AM
  #52
goliath88's Avatar
Engine: 305 tbi v8
so, guess what i did.. dropped that tank after troubleshooting like crazy.
and guess what i found?
... a plastic bag.
yeah, a damn plastic bag in my tank!! as soon as i dropped it and looked inside i saw that bag wrapped up on the filter. didnt let it get any gas. put everything together, went ahear and removed the rear spring isolators just to see the difference, and cranks right up.
im telling you, ima have to keep a closer eye on this car. idk why people get the need to mess with cars.
but thanks again tuned for the help brotha. hopefully this is the end of that nonsence.
Old 03-27-2013, 11:59 AM
  #53
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Omg that's crud, hope it didnt allow the pump to overheat much, a locking gas cap and a shot gun might be a good investment lol
Old 03-28-2013, 07:15 PM
  #54
goliath88's Avatar
Engine: 305 tbi v8
yup.. this some **** here. but i got my area security guard watching it now
Old 03-28-2013, 07:17 PM
  #55
Engine: Lb9
Transmission: M20
sucks you had to go through all that ;(
Old 03-29-2013, 02:55 PM
  #56
goliath88's Avatar
Engine: 305 tbi v8
P.O.S
Old 03-29-2013, 03:05 PM
  #57
goliath88's Avatar
Engine: 305 tbi v8
Effing died again.
Old 03-29-2013, 03:12 PM
  #58
Engine: Lb9
Transmission: M20
Do you have a fuel pressure tester ? I'm thinking the bag was in there for a while and it overheated the pump I'm sorry to say. Just a guess though.
Old 03-29-2013, 05:14 PM
  #59
goliath88's Avatar
Engine: 305 tbi v8
Yea man I do. That's why I'm thinking. I'm a pro àt dropping this tank now so its whatever. Just getting stressed out. SCHURK mentioned something about a circuit, anyway to test that? I checked the green wire that goes th the relay to see if it lights up and it does.
Old 03-29-2013, 06:08 PM
  #60
Engine: Lb9
Transmission: M20
On the tan/wht you will have power for 2 seconds with the key on, after that when you crank you will get power when the ops closes.
Old 03-29-2013, 11:12 PM
  #61
goliath88's Avatar
Engine: 305 tbi v8
What if the ops doesn't close? Will that cause a "dead pump "? The pump wont turn on?
Old 03-30-2013, 12:37 AM
  #62
Engine: Lb9
Transmission: M20
If the ops is bad the pump will not run. You can jumper the ops orange to tan/white the pump should run. It is a normally open switch and at 4psi or higher the contacts connect and the pump will run.
Old 03-30-2013, 12:42 AM
  #63
Schurkey's Avatar
The fuel pump is powered by EITHER the fuel pump relay, or the oil pressure switch.
If EITHER the fuel pump relay/wiring harness or the oil pump switch/wiring harness works, the pump will run.
The oil pressure switch system is a "back-up" to the fuel pump relay. Failure of the relay may cause extended cranking time--long enough to build oil pressure, close the contacts in the oil pressure switch, and then the pump pressurizes the fuel system.
If the fuel pump relay works properly, the oil pressure switch isn't needed.
Old 03-30-2013, 10:48 PM
  #64
goliath88's Avatar
Engine: 305 tbi v8
got it Schurkey. sounds like im visiting my gas tank again. noo sweat lol.
Old 04-02-2013, 10:36 PM
  #65
goliath88's Avatar
Engine: 305 tbi v8
sup tuned,
any fuel pump recommendations? im thinking going with a tpi pump, but dont want any issues with the excess pressure. what you think?? get a tpi pump? car is booone stock
Old 04-02-2013, 10:44 PM
  #66
Schurkey's Avatar
I put an ACDelco EP241 on my '88 K1500; works fine. Pressure is controlled by the TBI regulator, not the pump.
The photo of the box on the Amazon web site is one I submitted.
ACDelco EP241 Electric Fuel Pump : Amazon.com : Automotive ACDelco EP241 Electric Fuel Pump : Amazon.com : Automotive
Old 04-02-2013, 10:46 PM
  #67
Engine: Lb9
Transmission: M20
I agree the delco ep241
Old 04-03-2013, 10:55 AM
  #68
goliath88's Avatar
Engine: 305 tbi v8
What's the difference between that one and the EP386? Except for pricing? I believe that's the model number.
Old 04-03-2013, 10:58 AM
  #69
goliath88's Avatar
Engine: 305 tbi v8
I take it that the AIRTEX brand is garbage?
Old 04-03-2013, 11:11 AM
  #70
Engine: Lb9
Transmission: M20
The EP386 is a lower pressure pump and is for tbi so it will work well. Airtex = Do you enjoy dropping your tank , If your not in a real rush look for deals on ebay Delphi pumps are generally the same think you get in a acdelco or gm packaging.
Old 04-03-2013, 11:13 AM
  #71
Engine: Lb9
Transmission: M20
Do not buy a walbro just a fyi, years ago they had a bad batch that cost some turbo guys there engines. The walbro pumps have more of a amp draw and need a heaver gauge wire and relay so the pump will not burn it self out real quick.
Old 04-03-2013, 11:23 AM
  #72
Schurkey's Avatar
I originally bought an Airtex pump for my K1500.
I won't install a Chinese pump. It's just too much labor to do it again when it fails prematurely.
Old 04-03-2013, 12:47 PM
  #73
goliath88's Avatar
Engine: 305 tbi v8
lol im not too fond of it lol. so the ep386 is for tbi setup/ thats weird cuz i was looking up iroc 5.7 pumps and that came out
thanks Schurkey ima stay away from that brand, not worth trying to save 20 bucks to redo this job again .
so delphi, or ac delco... but for sure run a tpi pump?
Old 04-03-2013, 01:09 PM
  #74
Engine: Lb9
Transmission: M20
http://parts-catalog.acdelco.com/cat...tock_check.php
I tpi pump will work fine and may have the same life as a tbi pump as long as you don't starve it for fuel much ( run out of gas).
Therotically a tbi pump puts out less pressure so when you regulate it down to 12 psi the pump is working harder.
Old 04-03-2013, 01:44 PM
  #75
goliath88's Avatar
Engine: 305 tbi v8
[quote=Tuned Performance;5528959]http://parts-catalog.acdelco.com/cat...tock_check.php
so youre saying that if i put the tpi pump at 12 psi, its gonna work harder?
Old 04-03-2013, 01:48 PM
  #76
Schurkey's Avatar
No. Life is very easy for a fuel pump regulated to 12 psi. They "work harder" as the pressure INCREASES.
40--50 psi is not uncommon for port fuel injection. Sometimes higher.
Old 04-03-2013, 04:45 PM
  #77
goliath88's Avatar
Engine: 305 tbi v8
thats what i was thinking, guess i misunderstood. 241 it is . hopefully this resolves it. i noticed my ops had oil inside the connector, ima clean it up and see what it does. but found the pump for cheap so just might buy it and keep if i ever need it.
Old 04-09-2013, 06:52 PM
  #78
goliath88's Avatar
Engine: 305 tbi v8
well, dropped it again. and i started troubleshooting the sending unit. seems that there was a bad ground , and the harness to the sending unit was rusted out. i cleaned it, hit the connector with a brillo pad, cleaned it up again, and kept checking the ohmage over and over and over. as for now, the car runs again, have restarted it like 5 times. hopefully, this can keep this way til i can get the new harnesses. I dont wanna spend all the money on a new sending unit but if it must be done, then i guess i gotta do what i gotta do.
hope you guys are doing great. thanks again for allllllllll the help.
Old 04-09-2013, 07:40 PM
  #79
one92rs's Avatar
Car: SOLD!!!!!
when you figure out the problem install one of these. takes the load off the original harness. I have been running one for over a year and it works great.
http://racetronix.biz/mmWEBSTORE/Images/FL98.jpg
http://racetronix.biz/itemdesc.asp?ic=FPWH%2D005&eq=&Tp=
Old 04-09-2013, 09:08 PM
  #80
naval_ned's Avatar
Lists this part for TPI did you have to make any modifications for TBI or did it all work the same?
Old 04-09-2013, 09:36 PM
  #81
one92rs's Avatar
Car: SOLD!!!!!
nope not at all. plugged right in.
Old 04-11-2013, 09:17 PM
  #82
goliath88's Avatar
Engine: 305 tbi v8
damn, that looks real good. future upgrade for sure. my problem is now in the tank. so far, its starting up. toooooo scared to drive it outside my complex. thanks though One92.
RazorN8
01-07-2022 11:44 AM
9192camaro
16
02-03-2019 12:21 AM
mustangman65_79
04-14-2017 05:37 PM
92camaroJoe
08-13-2015 06:07 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: fuel pump relay harness pinout ( wire colors)
