Engine turn off when I change gears...
Old Jun 13, 2013 | 02:08 PM
BustaZz's Avatar
Hello,
first sorry for my bad english but I hope you will undestand me what i want explain to you
I have problem with my Trans AM WS6 1992.So the car run great the problems come when i stop in junction,traffic lights or just i want parking somewhere, when i change gear from D to N or R rpms make big drop and then engine is off. I Repeat this happens only when the car stay on one place with engine on...
Please help me
Old Jun 13, 2013 | 08:52 PM
Schurkey's Avatar
Re: Engine turn off when I change gears...
Does the engine idle if you AREN'T changing gears?
Idles in Park?
Idles in Reverse?
Idles in Drive?
Dies only when you CHANGE gears?
Old Jun 14, 2013 | 12:15 AM
BustaZz's Avatar
Yes only when the car is in idle and only die when i change gear from D through N and when i change it to R the car is die.Same from R through N to D and engine die. Please take note when car is driving and i want change from D to N and I back to D there no have problem
Old Jun 14, 2013 | 09:55 AM
Schurkey's Avatar
If it ONLY dies when you're changing gears, I'd be looking for defective wire harnesses that are being pulled/pushed/disturbed as the engine rocks on the motor mounts.
For that matter, defective mounts might allow excess engine/transmission movement.
If the engine doesn't idle correctly WITHOUT changing gears, I'd have said to look at the Idle Air Control and idle speed in general.
My suspicion is that the engine simply doesn't idle properly, changing gears may make the engine stall, but even without changing gears the idle isn't right.
Old Jun 14, 2013 | 11:36 AM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Timing could be off just barely.
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
