I'm stuck! Please help!!
Old Jul 3, 2013 | 01:36 AM
Braxton16's Avatar
Car: 1992 camaro rs
Engine: 305 v8 stock
Transmission: automatic stock
So this is my story.. I drove my car to my buddies house and it ran fine, went to leave and I got nothing wouldNt turn over. So I thought that it was probably just my starter that's been going out for a long time. I put a new stRter in and nothing.. So I got fed up and ran a wire straight to my starter from my ignition wire under the console. So then it cranked over. But now there's no fuel or not enough fuel depending on its mood. So I put a new throttle body on it. Still barely runs it will run really really rough and I can't give it to much gas or it bogs out. So then I thought it must be my fuel pump and or filter replaced both or those. Still nothing. And it only gives fuel sometimes? Im about to give up! Please help I have no idea!
Old Jul 28, 2013 | 01:47 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: I'm stuck! Please help!!
Clean your key- maybe the resistor in the key is going bad, and that would also explain no fuel, etc.
Can you hear the fuel pump kick in when you turn on the key?
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
