Is this a miss?
Old Aug 7, 2013 | 11:12 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Is this a miss?
Ok guys so i did a search and didn't find my exact issue. 305 automatic, When started it idles and runs fine while cold. After warming all the way up it still runs and drives fine but at idle in park i get a pop every few seconds. Not like (pop pop pop pop pop) like (pop 1 2 3 4 5 Pop). Its only every few seconds. Not really sure if its something to be worried about, i just know it ain't normal. It comes from the exhaust not the intake. Any ideas. All mods I've done are in my sig. Thanks in advance.
Old Aug 14, 2013 | 08:56 AM
mu33rto's Avatar
Car: 1992 RS
Engine: 305 5.0L V8 TBI
Re: Is this a miss?
Been having the same problem. Let us know if you figured it out.
Old Aug 24, 2013 | 11:10 AM
bigreed91's Avatar
Car: 1990 camaro rs
Re: Is this a miss?
Yeah i still aint figured it out, still only does it after warming up. Hopefully a full tune up will resove it, i just aint got the money at the time.
Old Aug 24, 2013 | 01:40 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Re: Is this a miss?
is your timing in the right degree
Old Aug 24, 2013 | 05:47 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Re: Is this a miss?
From the description sounds like backfire or "popping" through intake. If able, make a vid and post on youtube.
Old Aug 27, 2013 | 03:03 PM
bigreed91's Avatar
Car: 1990 camaro rs
Re: Is this a miss?
I believe the timing is right, i'll have to check it. I checked it last year but i don't remember what it was at. I believe its coming from the exhaust though not the intake cause the sound comes from the back of the car, not from under the hood.
Old Aug 27, 2013 | 03:17 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Is this a miss?
Popping in the exhaust is from fuel burning after it has left the combustion chamber, or while an exhaust valve is not fully closed. It could be that the motor is running rich or the timing is not correct.
Old Aug 27, 2013 | 03:24 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Re: Is this a miss?
I would check timing and coolant temp sensor.
Old Aug 27, 2013 | 04:39 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Is this a miss?
Also check the distributer cap and wires.
Old Oct 16, 2013 | 05:02 AM
bigreed91's Avatar
Car: 1990 camaro rs
Re: Is this a miss?
Well my timing is advanced 4*, i took the advice from pound and agreed it seemed like it was running rich at idle. I just got done moddifying my air cleaner by cutting the base out and making a bowl to flow into the tbi. I have pics of it in my fabrication thread. Anyways the tbi is open a lot more now and it now isnt popping at idle anymore with the extra air able to get in now. Hopefully i'll notice some better mpg numbers.
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
