What do I need to make this ZZ4 TBI setup work?
My Roadmaster's L05 is slowly eating itself apart so I picked up a complete ZZ4 on craigslist for $400. Needs to be rebuilt, have it half apart so far. I'm totally new to GM (only euro stuff until now) so I don't know what brands of aftermarket to trust, where to get quality stuff, etc.
The ZZ4 came with a 1709330 Rochester TBI setup, I'm thinking I can just reuse that or what's on the L05 and have it tuned in town. Or should I jump up to the 2" setup with 454 injectors? I'm not looking for big power (although if its easy to get I won't say no) just a reliable motor. The car had its fuel pump replaced and I haven't been underneath to see what model it is.
Can anyone suggest a good list of parts for this setup? Valves, springs, all that jazz. I feel like Helen Keller at an art gallery looking at all the options I have.
Thanks,
Morel
Thanks,
Morel
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Comp, crower , lunati, crane , Howard's, etc these are all big valve train companies ... And u will need some type of tuning plan to tune the ECM
Re: What do I need to make this ZZ4 TBI setup work?
First Guess: Given your application, there's not a thing wrong with the valvetrain components that you already have, as supplied by GM on the ZZ4 engine. That stuff is better than some of the aftermarket parts.
How you're going to get the computer to play nice with the ZZ4 camshaft is beyond my skills.
If you were to add a more-mild camshaft, you could still use the lifters, pushrods, rockers, valve springs and retainers you already have (provided they're not worn-out.) If they are worn, you could buy stock-replacement parts for a ZZ4 and be fine.
Among your issues will be the lack of an exhaust-crossover passage in the ZZ4 cylinder heads. You're gonna have fun figuring out how to retain the EGR.
Well, I thought it was a ZZ4.
10243880 Block
14102193 Heads, 87-up, 305/350, 1.94"/1.5" valves
Don't know what cam is in there yet, only top end is disassembled.
And to my understanding these heads are the same heads that are on my L05. If I can find something worth upgrading to, I'll do that. Otherwise its just picking which set is in better shape.
10243880 Block
10243880 Block
10243880 Block
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The Roadmaster is my $1200 everyday beater. Actually use it quite often as a shop vehicle. Low end grunt and decent mileage is ideal. So far I have $400 spent on this second engine, so another $600 as all I'd like to spend.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
If its just a cruiser do a mild set up..
Get an RPM intake with a TBI adapter plate
Mild port job on the swirlies
1.6 rockers with a spring upgrade
And an S10 4.3 stall converter.
Full exhaust from headers into a MANDREL bent 3 inch exhaust with muffler of your choice.
That would be stupid easy to tune and could be done for less than a grand if you scower eBay or craigslist for parts and can do the work yourself.
Go back to the criminal that sold you a swirl-port engine as a ZZ4, and get back the $200 he cheated you out of. Two hundred is all a roller-cam swirl-port engine in need of a rebuild is worth. MAYBE $250, if the bottom-end turns out to be exceptionally good.
Do you at least have the roller-lifter version? That'd be stock in a Roadmaster in '92. The pickup engines were flat-tappet junk; I wouldn't pay more than a hundred.
^ a bit late for that, oh well. My local supply isn't exactly booming, I'm in Bozeman, Montana. It was $300+$100 in gas to get the thing. It ran fine and is in ok condition inside the heads and piston tops, but needed to be cleaned up.
I'll know that on saturday once I get in the shop. Will it still be relatively plug and play if it's a flat tappet block?
As long as you retain the stock cam, or use a nearly-stock cam.
Don't expect more than stock horsepower, though. The way you describe your goals for the engine, you'll have what matters most to you: Low-end power, reasonable fuel economy, good durability.
Car: 1991 firebird
Axle/Gears: 4.10
The 1991--'93 "B/D Body" (Car) engine should have roller lifters and flat-top pistons. (9.6:1 compression.)
The 1987--1995 pickup-truck engine has flat-tappet cam, and dish pistons. (9.25:1 compression)
Expect marginally LESS power if you replace a properly-functioning car engine with a properly-functioning truck engine, due mostly to compression ratio decrease. Cam specs on either engine are so mild as to make little difference.
When the original engine in my pickup died at 230K, I installed a "crate motor" intended for the '91--'93 cars, p/n 12513151. Power was up slightly from the original engine, but it wasn't night-and-day difference. Frankly, I was disappointed that the power increase wasn't greater.
Seems to me the oil pan is slightly different, too. The pickup pan may not have a boss for the "low-oil" sensor. used on some cars.
Interesting. Thanks for all the info so far.
Marginal power loss is no worry for me as I've been babying the LO5 (not running on all 8, losing oil pressure) and have been happy with power on hand.
Terrell351
Jun 13, 2021 01:13 PM
db057
Aug 11, 2015 10:11 PM
