Backfire Through TBI on Acceleration
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
1984 Crossfire Corvette - Getting TBI backfire with moderate throttle under load. Only a soft gradual throttle will eliminate the backfiring.
Reading it may be valve timing or a bad valve or timing or ECM or..... With the following compression readings can I eliminate valve timing and a bad valve?
Readings cold, throttle closed, all other plugs in.
First Cycle/Fourth Cycle.
#1 110/152
#2 110/152
#3 100/150
#4 97/150
#5 98/151
#6 90/140
#7 100/150
#8 100/150
Other Specs
355 Rebuilt with ~ 300 miles on it
75# Injectors
Renegade Manifold
2" Bored TBI's
SBC Street Fighter Cam (Mild Mod- Have Specs)
9.72 to 1 Compr Ratio
Regulated Fuel Pressure
High Perf Fuel Pump - Not sure of specs
Have EBL Set-up - but have not run VE Learns yet - thinking the the backfire issue needs resolution first.
#1 110/152
#2 110/152
#3 100/150
#4 97/150
#5 98/151
#6 90/140
#7 100/150
#8 100/150
Other Specs
75# Injectors
Renegade Manifold
2" Bored TBI's
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Backfire Through TBI on Acceleration
I could not tell from the compression readings. But did you already check the spark plugs, fuel pressure and double check initial timing?
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
I did. Ran through these and others (TPS, Map, O2, Vacuum) more than once. Got frustrating. Why I was thinking valve timing. I'll have to try that accel enrichment adjustment. My laptop battery died so it will be a bit.
Was hoping the compression readings eliminated the potential of a valve issue. Thanks.
Car: 91 Trans am
If no signs of oil combustion on the spark plugs, then it is probably timing and/or fueling related.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
A better test of valve sealing would be a leakdown test using compressed air injected into the spark-plug hole. ANY leakage past intake or exhaust valves (hearing air escaping from the throttle body or tailpipe) is not acceptable. ANY air escaping into the radiator (bubbles in the cooling system with rad cap removed) is unacceptable. SOME, minimal leakage into the crankcase (hearing air escaping out of the oil-fill hole in the valve cover) can be acceptable, but too much is not acceptable. A real leakdown tester can put numbers to the leakage helping you determine what's acceptable leakage into the crankcase.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Progress - still waiting on a laptop battery (China express) but I built a manometer and balanced the TB's. In the process I jacked the idle up to about a grand - not intentional. Thought you couldn't do that
... anyway, will have to drop that later when I change the injectors and now I have a balancing under my belt.
During the test drive I noticed less backfiring. Guessing that's cuz I'm pumping more fuel into the manifold with the higher idle - that's probably a good indication it is a fuel enrichment issue. No?
... anyway, will have to drop that later when I change the injectors and now I have a balancing under my belt.During the test drive I noticed less backfiring. Guessing that's cuz I'm pumping more fuel into the manifold with the higher idle - that's probably a good indication it is a fuel enrichment issue. No?
Verify timing.
But with the manifold you use and the 2.0" TB it needs a lot more AE. I would start with 10% more AE for TPS and MAP both. You may see improvement. From there add another 5% and again see how it responds. You may end up with a lot more needed yet.
you have a very large intake and TB's. It all needs to be wetted. When you left off gas or depress the throttle Vac decreases and it goes dry.
Be aware the EBL allows you to add more at certain RPM's. You may find it needs more <2000 rpms but not > 2000 rpms.
I had a similar set up on my 84 CF.
Car: 91 Trans am
Going by the description of the new engine, I would first set up fuel pressure and a new bin with the basic adjustments, according to the new hp output, if it has not been done yet.
These links contain input that may help you if needed, to set up the new bin
https://www.thirdgen.org/forums/post...4-post178.html
https://www.thirdgen.org/forums/post...0-post207.html
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Thanks for the advice/direction, guys - exactly what I'm looking for. Picked the right forum. Will post results...
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Took it out today and it seems to be running worse. Missing and backfiring on the slightest load. This without touching anything.
Reading the referenced posts - not understanding much yet - so many options - where to start. Will have to hit the books & Dynamic EFI's tuning intros again. Will keep your suggestions in mind as I'm going through things but I have a ways to go before I can even appreciate "em. Will be back...but not for a while. Probably need to start with some basic VE learns - if there such a thing. Thanks.
Car: 91 Trans am
Once your laptop is operational, post a complete list of the engine specs including cam, so we can help.
Once you a have a base bin, set up for your engine, it will be the good time to do VE learns.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
75# Injectors
Renegade Manifold
2" Bored TBI's
SBC Street FighterHydraulic cam 288°/292° .450/.460 lift. Duration @ .050 lift 224/224° degint/exh, lobe seperation 114°, advance 2°
Will hook up to EBL later today. Recommendations on where to start? Thanks.
Car: 91 Trans am
75# Injectors
Renegade Manifold
2" Bored TBI's
75# Injectors
Renegade Manifold
2" Bored TBI's
Cam intake and exhaust centerline, cylinder head flow numbers and valve size, exhaust, intake manifold flow numbers
Car: check
Engine: check
Transmission: check
As for the AE, start by multiplying the MAP & TPS AE PW tables by 1.2 (20% higher).
Then multiply the MAP & TPS AE Filter tables by 0.9 (10% lower). This will increase the duration of the AE event.
But make sure that the fuel pressure is stable, otherwise the tune will go in circles.
RBob.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Make sure that the fuel pressure is stable and holds under load. Using a pressure sensor and logging it is the best way.
RBob.
RBob.
Car: 91 Trans am
I use the Actron 7817, with the T on the feed line next to the alternator, nothing fancy, but it works.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Just replaced injectors today with a set of 90's I bought last year. Started fine - no road test yet.
Actually not real sure now what the old ones where - was told they were 75's.
Part number on one of the old one's indicated it was a 40, the other had no part number. Anyway, planning on re-setting fuel pressure to 18psi - per BPC calc should yield about 400 ponies. Plenty for me - any comments?
Checking timing in the morning then will set up new bins then start working suggestions from there - think this makes sense if not let me know - thanks.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: 91 Trans am
I put the gauge under the wiper arm, to verify if pressure drops under load. Pressure must stay constant.
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Car: 91 Trans am
Mine is just long enough to go from the T next to the alternator to fit under the wiper arm, though I bought it around 8 years ago, not sure they are still made the same length.
Car: 91 Trans am
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
RBob.
Changed BPC vs VAC and BST-BPC vs Boost to BPC Calc Values
Added 20% and Reduced 10% Values Noted Per Above
Set AE->TPS% Double Map AE to 100% per Tuning Instructions
Saved values and new BIN
Flashed new Bin
Test Drove....
Still getting backfire on accel with slightest load. Little performance change noted.
How can I verify values were accepted by ECM?
Also, no way of testing stability yet - part on order though.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
In WUD you can always download BIN file from ECM into a new file and perform BIN file compare in the TP.
Just a sanity check - how do you check your base timing???
//RF
//RF
Car: check
Engine: check
Transmission: check
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Engine at Op temp, bypass disconnected, timing light. Engine starts right up - if that's an indication of anything. Anything else I should be checking? Thanks.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Thanks will look at this. I'm thinking maybe I should recreate the BIN starting from scratch just to ensure nothing crept in there to create issues. Recommend a base/starting BIN?
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Additional specs(?) I found this looking through some papers. It was handwritten on the engine rebuild invoice. I did not deal directly with the rebuild shop and parted company with this mechanic not on the best of terms. (He wanted to carb it against my instructions.)
Exactly as written - not sure if any of this helps.
Aluminum Heads
CAM 050 224/224 114° Lobe Sep 2°
In .450 Lift
Ex .460
Heads 245 at .450 Lift
64CC Flat Piston
9.72 to 1 Compression
Another shop pulled the engine and installed a new balancer - they could have distorted the cam timing. Does the engine need to be pulled to check this?
Car has long tube headers installed.
When I flash in a new bin I typically name it by that/todays date. Sometimes I add after date ae or pe or propgain whatever the change was. Like 060514propgain.bin. If the flash goes well you will see the green acknowledgement message and the dash light will blink. Be assurred it is running on the new bin.
Car: check
Engine: check
Transmission: check
RBob.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Yes, there are constants in the conversion formulas that limit the amount of change. VE tables,as an example, must change > .39%. Having said that, I have found that I can 0 out a value, save the bin, then replace the 0 w a new value even though it was < .39% than the original VE. Don't know what the value of this may be.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Revving it made it jump initially another ~6 then it stopped moving when revved after that. Shouldn't I see it advance more as I kick up the RPMs?
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Have you verified that dizzy is positioned correctly? That you are not one or two teeth off on cam drive? Just askin.
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Can you elaborate on your set up and how the test is performed or reference a thread? Where does that run-off typically go as you're driving?
Thanks.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Take the D/S valve cover off, turn crank until balancer mark is at 0 or maybe 6d TDC. #1 I/E valves should both be closed. Now look at distributor rotor. Is it pointing at # 1 cylinder on dizzy cap? It should be right there. If not, you're distributor is not set properly.
Car: '83 trans am Lear Siegler
Going back to basics, I've seen plug wires do exactly what you are describing several times. Try a spray bottle with the engine running in the dark and watch for sparks. Dist. Cap can do that too.
