rough idle in drive 305 TBI
Old May 2, 2014 | 09:40 PM
Kevinfirebird's Avatar
Car: 1992 Firebird KITT
Engine: 305 TBI
I have a 92 firebird 305 tbi
I have a rough idle in DRIVE when im at a stop, but idles nice in park. The car runs and drives awesome.
It started after i replace a fuel injector that went bad, i only replace the bad one.
I also change the IAC still the same and the tune up is about 4-5 mounts old.
Its has AC Delco plugs and plug wires.
I don't know whats causing it.
Old May 3, 2014 | 07:31 AM
ex-x-fire's Avatar
Re: rough idle in drive 305 TBI
Make sure the egr valve isn't getting vacuum at idle (in gear or not).
Old May 3, 2014 | 10:37 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Check VA leaks also.
Old May 3, 2014 | 12:18 PM
Engine: 305 TBI
there's no vac leaks.
Old May 3, 2014 | 12:20 PM
Engine: 305 TBI
I will try a new egr I have not changed it.
Old May 3, 2014 | 04:12 PM
ex-x-fire's Avatar
A new egr valve won't help if your erg solenoid is by passing vacuum to it. Buy a vacuum gauge & test it when it's acting up.
Old May 3, 2014 | 11:22 PM
Engine: 305 TBI
Ok i will get a tester and check it.
Thanks for the help ex-x-fire, and RS-Chevy-SS
specialized
Jun 18, 2022 09:26 AM
pimp2303
Jul 27, 2017 02:03 PM
Wade787b
Sep 29, 2015 01:15 PM
92purpz28
Aug 11, 2015 02:30 PM
