problem timing after rebuild
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
i just swaped my 305 block for a rebuilt one. i installed the distributor and set the time by hand. i went to roll it over to see if it would start and i get gas sperting up out of the TBI. what could this be? is it back firing or something along that line? any help would be great.
Engine: 305 tbi
Axle/Gears: idk
Re: problem timing after rebuild
Yep so I just reset tdc and that solved the back fire problem but it still will not fire up. I checked the plugs and there burnt. Could that stop it from firing?
Engine: 305 tbi
Axle/Gears: idk
stupid spark plugs! so i replaced all the spark plugs and the car fired right up. lol. after an almost 2 year rebuild it runs now. ( or so it looks like and we will see if it keeps going) now all i need to do it rap up the vacuum lines and im good to go.
Engine: 305 tbi
Axle/Gears: idk
now that its running im getting white smoke from my exhaust. the engine and exhaust system are new. is it just cause its new or do i have a coolant leak in my intake? any thoughts on how to tell before i pull the intake?
Axle/Gears: 10 Bolt 2.73 Open
You will get a little smoking from new pipes some times....oil left on the pipe surface from the forming process. But that burns off pretty quickly, and is coming off the outside of the pipe itself, not from inside of it.
I didn't see where you are from. I'm in Michigan, and when I start a car in this weather, it is not unusual to get a lot of condensation drifting out of the exhaust like a cloud. But this ends pretty quickly as the engine and converter warm up. But if you live in a cold climate, you already know that.
If the "cloud" coming from your exhaust does not taper ff as the car warms, or if it has an unusual, sweet aroma to it, then I'd say you have a coolant leak.
backtothe80s
Sep 5, 2015 12:39 AM
