help with timing.
Old Mar 2, 2015 | 08:09 PM
camsuper88's Avatar
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
help with timing.
So I just got my 88 305 TBI running. I put the timing light on it and it is on 7. What is the sweet spot for the distributor?
Old Mar 2, 2015 | 09:07 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: help with timing.
Check the link below. Explains it way better than I could.
https://www.thirdgen.org/forums/tbi/...ce-retard.html
Old Mar 2, 2015 | 09:15 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
read that, but is there a special number thats good? is 0 the best or is a little advanced better?????
Old Mar 2, 2015 | 09:57 PM
antares57's Avatar
"0" is the standard. You can advance it, depending on your vehicle, until it bogs down. Then stay at the previous setting. Takes some trial and error.
Old Mar 2, 2015 | 11:03 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Disconnect the EST wire, start car and idle until the car is at operating temp., adjust timing, shut off car , reconnect EST wire.
I ran at 4* advanced for a while but now prefer a stock setting of "0". That way everything is in sink and I don't have to bump it back and forth every 2 years for smog.
A digital gun like this is a must in my book. Makes a traditional gun seem like a rock. Gives RPM also necessary to set Minimum Idel Speed.
This is what I have =
Amazon.com: INNOVA 3568 Digital Timing Light: Automotive Amazon.com: INNOVA 3568 Digital Timing Light: Automotive
Old Mar 3, 2015 | 09:33 AM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
Ya I put my timing light on it but I can't really set it myself. Probably ask one of my friends to help today.
Old Mar 5, 2015 | 07:21 PM
Engine: TBI,5.0
Be very careful when working around the distributor hold down bolt. There are very small hard plastic vacuum lines that are brittle and can break easily.
Crack the one going to the MAP sensor and you will know it promptly.
You can see the one I cracked with a hose patch . It went to the MAP. It was not pretty on the next start attempt with it left broken.I never thought a sensor could have that kind of effect. I thought the TBI exploded.
I would buy a set of these. = http://www.oreillyauto.com/site/c/de...0716&ppt=C0374 Or try a Crowes foot that is taped to the extension so it does not come off.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Z28Man
Jul 27, 2001 11:57 AM
383GTABoy
May 30, 2001 07:47 AM
Grim Reaper
May 23, 2001 08:08 PM
