Holly Avenger EFI
Old Mar 10, 2015 | 06:46 PM
Txpo's Avatar
Car: 89 Formula Firebird
Engine: 305/5.0 LO3 TBI
Transmission: T5 5 speed
Axle/Gears: 3.08 limited slip
Holly Avenger EFI
Anybody running this setup? I'm thinking this will be my next upgrade along with Vortec heads.
Old Mar 13, 2015 | 11:01 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: Holly Avenger EFI
Try the alternative port efi board right below the tbi board, probably better luck gettin responses there. Also try searching for it im sure you'll come up with some answers.
Old Mar 13, 2015 | 05:43 PM
Txpo's Avatar
Thank. BTW I did do a search, nothing.
Old Mar 13, 2015 | 06:48 PM
bigreed91's Avatar
Car: 1990 camaro rs
Go to the alternative port efi board and then search just "avenger efi" many hits come up, and from what i saw, yes many people are runnin it, most going the stealth ram route. Hopefully you'd be making the same decision. I gotta ask though, why are you lookin to spend a couple thousand on a efi setup for a 305?
Old Mar 13, 2015 | 07:12 PM
Txpo's Avatar
It will fit on the 350 when I upgrade.
Old Mar 14, 2015 | 05:18 PM
Txpo's Avatar
Bigreed91, why would I go with the Ram over the standard style? I'm new to some of this so this may be a stupid question.
Old Mar 15, 2015 | 11:52 AM
bigreed91's Avatar
Car: 1990 camaro rs
The standard tbi uses 2 or 4 injectors in the center of the intake, your middle cylinders will always have a richer mixture than your front and rear cylinders. The tunnel ram is a tpi setup, meaning you have one injector per cylinder that sprays right behind the intake valve. Therefore not only is every cylinder getting the correct amount of fuel but the fuel is atomizing a lot more. Now hopefully its sequential port meaning each injector fires seperately, non sequrntial will fire all 8 at the same time, not a huge difference though and not very noticeable as fast as the engine turns.
Old Mar 15, 2015 | 04:45 PM
Txpo's Avatar
Thanks! That was what I needed to know
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
86CamaroDan
Sep 29, 2015 10:08 PM
rubyred88
Sep 17, 2015 02:19 PM
makaveli09
Sep 15, 2015 10:43 AM
