intake manifold?
Old Dec 18, 2001 | 06:06 PM
PimpCamaroRS's Avatar
intake manifold?
i have a 91 Camaro and plan on switchen to 350 with AFR heads, desent cam, and a 454 with #90 injectors. Now i ned to find an intake manifold that will work with my 454, EGR, and emissions in CA. any ideas?
Old Dec 18, 2001 | 06:12 PM
RSRagtop's Avatar
Their no off the shelf emissions legal intakes that I know of that will work with the 454 TB. You could use a carb style intake and an adapter, or you could get the Performer TBI intake and bore it out for the larger 454 TB ( if I remember right there is barely enough material to do this ).
Old Dec 18, 2001 | 06:55 PM
Tas's Avatar
Tas
Have the Edelbrock TBI intake bored for the 454 TBI. I REALLY doubt the inspector will tell the differance in the bores. There was an intake set up just like I said a couple days ago on ebay. www.ebaymotors.com
Old Dec 18, 2001 | 07:04 PM
NJ SPEEDER's Avatar
actually, teh holley street dominator TBI intake is emissions legal and it has the 2inch bores in it to accpet a 454 tb unit. you will need to find an older style EGR valve than is used on most late model f-bodies. if you find one from a carbed early 80's gm car it will work. it can support a good 350 breathing up past 6000rpm according to holley.
later
tim
Old Dec 18, 2001 | 08:03 PM
Tas's Avatar
Tas
later
tim
The last time I checked, the Holley TBI intake was not 50 State legal as it has no E.O. number even though it does have EGR.
Old Dec 18, 2001 | 08:49 PM
fast_broker's Avatar
Not an OEM TBI manifold. It is for ProJection and is not EO cert'd.
It'll work just fine, though.
But in my opinion, for the cost, get a carbed manifold with an adapter plate. more options, can go carb if need be, etc. I just screw around with induction a lot so it makes more sense to me... Maybe a comparison of runner size, plenum size/area is a good idea.
Old Dec 19, 2001 | 06:24 PM
intake
i cant find any where to even buy a projection holley TBI intake. Any one know where? Also what would i have to do to use a carb manifold? Like EGR, Adapter plate,Ect...thanx
Old Dec 19, 2001 | 07:39 PM
Tas's Avatar
Tas
aftermarket intakes:
www.summitracing.com
www.jegs.com
adapter plates:
www.holley.com
www.turbocity.com
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
