Tbi Not Firing Properly
The passanger side TBI does not fire like it should, there is no spray going into the TBI base. When i swaped the wires plugs on top the other one that I swapped it to didnt' fire. What might be wrong? The wiring? I followed it back to the fire wall were it plugs into whatever the hell that thing is. Some help as what i should look for.
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Did you try checking the injector fuses? Hopefully that's it. If not, it sounds like you're going to have fun chasing a short.
