Performance TBI??
Old Dec 18, 2001 | 09:24 PM
JuGrNuT350's Avatar
Performance TBI??
What kind of performance stuff can you do to a TBI 350.... I thinking Crane 104224 (.452/.465 214/220), Fast Burn heads & TBI Vortec intake.... or should I just go w/ a Tune Port w/ those same mods only the Scoggins TPI Vortec baseplate?? Which would get more power?which is cheaper? Is there anything you can do to the throttle body inself?
Thanks alot,
-Timbo-
Old Dec 19, 2001 | 09:22 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm getting a little over 300HP (at the flywheel)
with TBI.My reason for staying with TBI was mainly reliability.The original 305 went over 200,000 miles without any fuel injection problems.Also, it's a bunch less expensive than tuned port.
Anyway, my current setup consists mainly of a new crate motor from Autocenter,Crane compucam,Edelbrock Performer TBI intake,ported Turbo City throttle body and adjustable fuel pressure regulator,14"x3" Moroso open element air cleaner with K&N filter,SLP headers,Flowmaster 3" exhaust,3" cat,and a custom chip from Ed Wright at Fastchip.Turned my RS (came with 170hp) into a whole different car!Just finished building 3.73 geared posi, disc brake rear,that I'll be installing in January.
Anyway, my point is, that there's a lot you can do with a TBI, if you don't want to switch to TPI.
-Rich-
Old Dec 19, 2001 | 09:25 AM
fast_broker's Avatar
Nice numbers, Rich. Did you get the engine dynoed at 300hp?
Old Dec 19, 2001 | 11:45 AM
Car: 92 Camaro RS
Yeah it'a actually 310 HP at the flywheel,with the SLP headers and a single Flowmaster 3" 2 chamber muffler.That's with just the water pump being driven off the crank,no power steering pump,alternator or AIR pump.
Haven't gotten it to a chassis dyno yet to see what it has at the wheels with the accessories and full length exhaust.
-Rich-
Old Dec 19, 2001 | 12:09 PM
That motor is old news. I have ZZ4 cam with 1/6/1.5 GMPP roller rockers and Fast burn heads, Air Gap amifold on there now with the small TB unit. Esentially a FastBurn 385 but with 1.6/1.5 Roller rockers to help the breathing on the intake a bit and reduce friction.
I need a bigger 454 Rochester TB to get the PROM right before I bring this one there, and I thnk. This combo got 412hp with a 600cfm carb, I believe, on the dyno with my headers and muflers, H2O pump, full serpentine package with no alternator/AC load. With TBI, it runs REALLy well up to 4000rpm right now on only the 3rd PROM, but stopping PROM work because it is obvious I need more air AND fuel to get to my 400hp goal. It is a DREAM to drive right now, though. Really crisp, great mileage, really nice. Little Open loop (while warm) leanness on the AF monitor but I forgot to drop the AF by 0.5 (from OEM) all around on the last PROM. That'll cure it, it always does.
I typically get a 21-23% loss on the chassis dyno in my wrangler.
Old Dec 19, 2001 | 12:14 PM
Car: 92 Camaro RS
Wow, that's awesome.I bet most people can't believe it's TBI.How long have you been burning your own chips? Is the EGR functional?
Old Dec 20, 2001 | 12:03 AM
JuGrNuT350's Avatar
So If I ran: Turbo City Ported TBI, Vortec intake for TBI, Crane 104224 cam(.452/.465 214/220), Fast Burn heads w/ 1.5rr, custom chip,K&N open element, Flowtech headers, tru dual exh., shift kit, 3.73 posi approx. how much would I have at the flywheel?? I know there are a lot of variables as far as hp & torque go, just ballpark figures.
Thanks,
-Timbo-
Old Dec 20, 2001 | 08:48 AM
I would just use the Vortec heads with that compucam. Plenty good enough if you just add better springs. Won't even need to put in screwed-in studs in that app, IMO.
Noone believes my truck is TBI. When I lift the hood, everyone I have taken for a ride looks for hidden nitrous... The bad part is that it's a Wrangler. High speed handling and braking aren't its finer attributes. Really pisses people off, though, if they decide to race, which EVERYONE does. I have a rather lod exhaust and most people don't suspect a V8. They think "listen to that guys 6-cylinder with that exhaust! Watch this, honey!". I have to laugh!!!
I swear that I may never use a carb again on the street and if I can find a way to use a 7747 to run just the distributor curve with a carb, I'd do that. Just runs that good all the time. Almost too good to believe.
I don't burn my PROMS although I have all the equipment new and in the box, still. I use Tunercat to manipulate, then email the BINs to a buddy/client who burns the PROMs and mails them back to me.
Old Dec 20, 2001 | 06:54 PM
Dan W's Avatar
Spark only 7747 here --->
fastbroker... I think this is what you were looking for.
http://www.diy-efi.org/gmecm/ecm_inf.../747_ignition/
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
scottmoyer
Sep 7, 2015 07:06 PM
