engine temp/fan temp
Old Dec 21, 2001 | 10:19 PM
Buck268's Avatar
Ok, first, I am damn sure I am running hot. I will get up to 220 easy in mild weather. Often to about 245
My question is two-fold.
First: Isn't a fan supposed to kick in @ 195 or something? mine dont come on till 240-250*
Second: Any other reasons I could be running hot
- 190* temostat
- rebuilt radiator with about 1000 miles on it
- New ECM, original PROM
- new CTS, but I think the plug/wiring harness need replaced as I will sometimes get a SES light.
- A/C (never use it)
- car over heated pretty good right before I bought it
I believe this could be a root of most of my engine related problems. I bet its real obvious, but I dont see it. thanx fer any help!
Old Dec 21, 2001 | 10:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
do you have an air damn under your car? also i would put in a 180* just for the heck of it
Old Dec 21, 2001 | 10:39 PM
Buck268's Avatar
yes, the air damn Is intact. maybe little worn, never seen a brand new one, so cant compare...
Old Dec 22, 2001 | 04:39 AM
DM91RS's Avatar
Car: 91 RS
Go to the tech section. Willie has written an article about this.
I installed a painless wiring switch that cuts off at 180 and on at 195 and it works great. I also have a toggle switch that can manually cut it on when needed. They both work great.
Old Dec 22, 2001 | 09:18 AM
Buck268's Avatar
Yes, I was more asking about hte temp that it SHOULD come on, when I get time, I do plan on copnstructing a switch for the fan, though...
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
