Where does this connect?
Old Jan 30, 2016 | 09:13 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Transmission: 700-R4
I'm trying to figure out where this port on my air cleaner, actually connects to. I out lined the port with a yellow box.
Does anyone know what this connects to? and maybe a picture ?
Old Jan 30, 2016 | 10:46 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Where does this connect?
Connects to the opening in the valve cover.
Old Jan 30, 2016 | 11:42 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Yes, there should be a rubber grommet in the valve cover hole that the end of that pipe pushes into.
Put a little engine oil on it first to help slide it in.
Its very easy to push the rubber grommet into the valve cover if your not carful.
Old Jan 31, 2016 | 01:08 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Ok awesome!
Does anyone know what that tube is called?
also, Does anyone know where this tube connects to that i have outlined in red?
Old Jan 31, 2016 | 07:22 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I believe that hooks to the throttle body (provided that your car is fuel injected), there should be a vacuum port that has nothing attached to it.
Old Feb 1, 2016 | 07:41 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Ok thanks guys! Tell me, Does the crank case vent tube that we are talking about, does it connect to the valve cover via a valve cover breather? or how does it connect to the valve cover?
Another question:
Where does this line connect to ? I have the line colored red.
ON this emissions diagram, it says that the line connects to the "s" port on my throttlebody.
As you can see, my "S" port, has like ugh.. no connection? It just has a inward divet in the metal.
Am I missing something?? Or where does this Temp Sensor connect to?
Old Feb 2, 2016 | 03:24 AM
Engine: TBI,5.0
That's a vacuum hose.
The hole your arrow is pointing at is not a vacuum port.
There is a screw in there that will adjust the throttle called a throttle stop screw.
Don't mess with it until you ask for help doing it.
My throttle body looks like this photo I found on the web.
It has four ports.
Apparently there are some out there with only three.
I'm not familure with them.
Someone ealse will have to step in and help at this point.
Old Feb 2, 2016 | 01:15 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
It has four ports.
Well ****! q.q thanks for the info though!
im niot sure if my throttle body is after market, or wahts going on here.
Old Feb 3, 2016 | 06:06 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
http://members.shaw.ca/howto/28to43tb/28to43.htm
Well this helped me out a lot lol. I thought i was going to have to drill into my throttle body. geez
Old Feb 3, 2016 | 10:01 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Old Feb 4, 2016 | 12:05 AM
B_Dubya's Avatar
Engine: 305 5.0 TBI
I'm going to just ""While you can splice in a "T" to the existing vacuum line on the opposite side of the throttle body it is suggested you do it right and put in a new port"""
splice a "T" to the existing vacuum line lol The left manifold vacuum.
That should be fine right?
Old Feb 4, 2016 | 06:36 AM
antares57's Avatar
Should be. I'd check vacuum pull before and after to see if it makes a difference.
Old Feb 5, 2016 | 01:18 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Thanks for the help everyone.
If you can think of anything else, please feel free to post it.
Jackrabbit501
Feb 6, 2016 08:38 PM
Jailescape
Jan 31, 2016 02:47 PM
lt500r55
Jan 30, 2016 07:09 PM
Jailescape
Jan 27, 2016 08:53 PM
sfusco3
Jan 23, 2016 03:07 PM
